Question about Diehl 1 Timer Module,1 Pole, Model 2a517 In Box
I need user guide for Diehl 884.1k timer
It's quite easy to find 884 guide, but this one is different.
  • Diehl Master
  • 5,245 Answers
Attach close-up photo or video of your product:
http://waterheatertimer.org/How-to-set-Vokera-mechanical-timer.html#PB
Of course fixya will degrade your photo so we can't see it anyway, but you could also describe timer in detail for best result.
gene h
Posted on Mar 31, 2014
Http://www.accesscontrolsales.com/pdf/diehl_pdf/887.pdf
Some timers have capacitor carryover for power outage.
This means timer does not need to be reset after power outage
Jun 15, 2014 | Diehl TIME CLOCK- 120V 24 HOUR
Can timer be shut off early
I have extensive files on timers.
Your timer is not identified by those numbers.
Copy following link to view diehl timer resources:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
Add a comment and describe timer in detail for possible identification
Jun 07, 2013 | Diehl Hardware & Accessories
Manual for diehl multi-timer typ 181-5
Timer number does not match Diehl timer numbers
1) Diehl timers and manuals appear on following links:
http://www.borggeneral.com/
http://www.borggeneral.com/diehl-control-timers.html
2) Add a comment with in-focus photo of timer posted on flicker for possible identification and more help.
Jul 19, 2011 | Hardware & Accessories
Need wiring diagram SPST power to timer timer to light . two screws marked timer 1 nc 1no 1 com
Here are two possible solutions, since timers are made different ways:
1) Diehl timer has 5 terminals
Drawing below shows wiring for Diehl SPST:
2) Your timer might also be wired as follows:
Two screws marked 'timer' are for 120Volt Hot and Neutral that power the clock motor (in drawing above, these are terminals 1 and 2).
Another Hot wire connects to COM. (in drawing above this hot wire shown connecting to terminal 3)
Load wire connects to terminal NO (in drawing above this wire shown connecting to terminal 4)
3) NO is Normally-Open turns ON when tier turns ON
NC is Normally-closed is ON all the time, EXCEPT when timer turns ON. So NC terminal turns OFF when timer turns ON.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 31, 2010 | Diehl TA-4150 24 Hour Electromechanical...
How do i wire my diehl 880 ?
1) Here is Diehl 880 instruction manual
2) Diehl 880 is 120V timer
-1/2 HP
-1000 Watt tungsten. Tungsten means incandescent light bulbs.
3) Checklist:
a) Your load does not exceed capacity > Timer is too lightweight to control 1500 toaster oven.
b) You need 120V line coming from breaker box with black Hot wire and white Neutral
c) You need 120V line going to Load that also has black and white wire
d) Test each black wire to ground to see which black wire is HOT
4) Deihl 880 sell sheet pdf says 880 is available SPST (single pole single throw) -or- SPDT (single pole double throw).
-The difference is pole #4 on the timer.
-If you are trying to turn one circuit off just as another circuit turns on, then you need the SPDT
-If you are turning one circuit on-and off, then the following instructions are for you
5) Wire clock
-There are 5 poles > look for markings 1-thru-5
-If no marking, then poles 1&2 are probably spaced apart from other poles
-Connect Hot and Neutral wires to poles 1&2 >> this powers clock motor, they go on either pole
-Pole 4 not used
6) Wire timer
-Poles 3&5 are timer circuits
-Connect Hot line to pole 3
-Connect black wire going to Load to pole 5
-Connect white wire from Load to Neutral
Oct 01, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
Diehl 1  Timer Module,1 Pole, Model 2a517 In Box Logo
307 people viewed this question
Top Diehl Hardware & Accessories Experts
Cameron Dyer
Cameron Dyer
Level 1 Expert
Gene Haynes
Are you a Diehl Hardware and Accessory Expert? Answer questions, earn points and help others
