Question about Blomberg DV16540
Not heat Dryer don heat
    Problem Solver:
  • 14 Answers
Probably need a heat element. a pretty easy fix. most likely you just take off front panel unplug old element and plug in new one. hard to say without knowing the model/ brand.
Posted on Mar 31, 2014
My drier has no heat. I don't here the gas kick in.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/,./
Sep 18, 2011 | Whirlpool WGD6400S Gas Dryer
Tip
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
Lg dryer dlg8388 , with power on drum runnng but no heating up, i'll check continuity in the igniter and is ok. don't lnow what else to check.
heatman101[
Aug 25, 2011 | LG DLG8388 Dryer
May tag gas dryer don't get hot.
heatman101
Aug 15, 2011 | Maytag Dryers
Wondering if I mounted the flame cutoff sensor in the correct way. Does it mount onto the side of the burner unit? The dryer is now working but seems to be running hot.
The cutoff switch don't control the heat. Just tripps if the dryer overheats. The heat is judged by this cycling thermostatlthemobilian_2742.jpg
Mostly these don't over heat. The probo gonna be up in here:
Clean that blower housing out and party on!
Aug 04, 2011 | Whirlpool LER4634J Electric Dryer
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
My amana electric dryer model number "NED7200TW" wont heat up. Everything else works it just don't heat it just puts out cold air. The exhaust was somewhat clogged outside but even after...
heatman101.,./
Jul 27, 2011 | Dryers
Dryer gives heat but don't run you don't hear the motor running
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Dryers
My Amana NED7200TW runs but will not heat up. I don't get any error codes. Help.
heatman101;
May 10, 2011 | Amana NED7200TW Electric Dryer
My dryer runs but don' heat up. It's about 15
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 29, 2010 | Whirlpool Dryers
Blomberg DV16540 Logo
123 people viewed this question
Top Blomberg Dryers Experts
L Pfaff
L Pfaff
Dado
David Ellis Rhea
Are you a Blomberg Dryer Expert? Answer questions, earn points and help others
