Question about JVC FS-2000 Shelf System
Aux in won't work
Bought some powered speakers and when using the aux out to them the aux in won't work. works fine as soon as the aux out is umplugged any advice?
2 Suggested Answers
  • 54 Answers
SOURCE: When playing from the AUX (i.e. iphone), can't hear from both speakers, only one; but when playing from a CD, the sound is fine. Any suggestions/advice/help? The odd thing is that if I press down
hi, seems like you may have a faulty aux jack socket(if the socket is mounted onto the face) or you may have some dry joints on the socket, or even a cracked pc board around the aux socket connections. also try cleaning the face connection pins both on the unit and on the face. if you not technically minded, check out you jvc repair center. cheers!
Posted on May 24, 2012
Mic won't work at auxiliary mode
On the remote control, there is a blue "Magic Mic" button. Press on that your mic will turn on in any mode.
Just joking but I've been mad about how bad this LG home theater system is. It can only play extremely limited video files and turn off the mic in AUX mode. So the answer is you really can't do that. Buy a mixer instead.
Jan 19, 2013 | LG Audio Players & Recorders
May 24, 2012 | JVC Kd-r310 Car CD/ MP3 Player
Hi I am having problems with my Panasonic SA-AK200 stereo system when in AUX mode. What happens is when I play through AUX mode The Sound only comes through One speaker usually the right one but when on cd...
Looking at your question, it appears that the problem is not always on the same channel (right/left). This makes me wonder if the problem is the source or the cables you are using. The easy way to test this is to connect everything, check which speaker is not working, then swap the left and right cables at the aux jack. If the same speaker does not work, then it is a problem with the SA-AK200. If the problem switches to the other speaker, the SA-AK200 is not the problem and you should try replacing the cables or suspect the source (whatever you are trying to connect to aux) is at fault. If the SA-AK200 is the problem, I would suspect bad solder connections at the input jacks. Good luck
Dec 12, 2017 | Panasonic Audio Players & Recorders
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
Last night my Compaq desktop was working completely fine and I shut it down normally using windows. Now this morning the power button wont turn the computer modem on! There is a green light that is...
try to umplug the modem from the motherboard last pci slot on the botom of the case if that works ok if not try new power supply if still not working problably bad motherboard thanks
Oct 13, 2009 | Compaq Presario 5000 PC Desktop
Working fine, then no sound coming from speaker whilst working on auxilliary connection to TV
the aux connection uses different connection on the rear interface, if this has never worked then it may be a compatability problem, if it has, then there is a failure on the rear input (aux). contact b and w service or supplier, they should repair and also update your power supply board.
Sep 09, 2009 | B&W Bowers and Wilkins Zeppelin iPod Music...
No sound from right speaker when mp3 connected through aux
Hi bustero78
What happens when you rotate the plug or wriggle it about. If it cuts in and out, then you may have a faulty interconnect lead, or a dodgy socket/plug connection to the player. If it works with headphones, I would suggest replacing the lead.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 02, 2008 | Denon AVR-1601 Receiver
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
TV stuck on AUX
unplug the tv then plug it back in the wall
Aug 30, 2007 | Orion1934 19" TV
JVC FS-2000 Shelf System Logo
43 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
