Question about Cameras
Programing a spa side controler power master pm3000
Trying to program
SOURCE: ZEN-SPA UNIVERSAL REMOTE CONTROL
Manually turn on the device( TV.,VCR,etc) to be controlled.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the code search button.
Press and quicly release the desired mode button(TV,VCR,etc).The red indicator blinks off once.
Press the CHaNNEL UP button repeteadly(up to 300 times) until the device to be controlled Changes Channel.The red indicator blinks off with each button press.If you overshoot the code required,press Channel Down button to backtrack through the library until the device changes channel.
Press and release MUTE to install the code.
Posted on May 29, 2008
PartsCenter
  • 125 Answers
SOURCE: Jandu Aqualink Pool/Spa Controller RS6
AQUALINK GUIDE BOOK
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
autotherapis
  • 501 Answers
SOURCE: programming replaced master door switch 06 trailblazer
No. not the switch. Check to see if you have power going into it. I don't have the wire diagram, but you can take a test light and check each line. At least one will light up with the key on. Certainly check your fuses.
Hope this helps
Posted on Apr 09, 2010
swolfinor
  • 504 Answers
SOURCE: Programming car remote using garage door opener remote control fo
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Posted on May 26, 2010
I have an Aqualink RS6 with a Jandy 6473-E control panel and my spa is being commanded ON without being told to. It will not do this when I have service mode selected at the power center. Thanks
make sure there are no spa programs if no programs remove the spa side controller plug if ok then replace spa side remote water could have damaged the wires
Sep 27, 2015 | Jandy Pool & Spa
Compool cp-3800 comes on in the middle of the night
see if set on heat maintain if on turn off if not disconnect spa side remote if same bad board
Mar 24, 2013 | Pentair Compool CP3800TX Pool & Spa...
How do I tell if my spa is in standard mode
I don't think this unit has a switch between economy and standard, it must always be in standard mode. Below is filter cycle programming in case you need that info.
Filter Cycle Programming
The first filter cycle begins six minutes after the spa is energized. The second filter cycle begins 12 hours later. Filter duration is programmable at the Master Control Pad for 2, 4, 6, 8 hours or for continuous filtration, (indicated by
"FC"). The default filter time is two hours. To program, press "Temp", then "Jets." Press "Temp" to adjust. Press "Jets" to exit programming.
Feb 01, 2012 | Qca Spas Dream Series Dream Master Hot Tub...
I have an aqualink RS8, which controls the on/off timing of the pool/spa, fountain feature, solar heater and yard lights. 1 - the display reads "6520 rev hh" 2 - the spa has been turning on by...
first disconnect the spa side remote if they go away replace the spa side remote if they don't go away go to system setup and go to programs either cancel if all button or delete or edit if one touch or PDA
May 25, 2011 | Jandy Aqualink Rs4 One Touch Control...
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
to delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Dec 26, 2010 | Jandy Aqualink Rs4 One Touch Control...
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
Pool lights go on randomly--not programmed to go on at all
make sure the light is pluged in a port that is for like a spare aux. any time you add programs you must hit the store button.
Oct 05, 2009 | Jandy AQUALINK RS TELELINK KIT
Jet blower randomly starts ...
most of the time this is caused by a faulty spa side controller. If you trace the line from the spa and disconnect it see if that solves the problem.
Jul 24, 2009 | Jandy Aqualink Rs4 One Touch Control...
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
