Question about Directv Televison & Video
Double vision tv my screen is displaying double picture ivetried tightening the cables and switching the channel its set to and still nothing it worked fine a few weeks ago and now this. any ideas on
All wires are connected, not loose worked before
techman
  • 3130 Answers
SOURCE: no audio on select channels
Go into the TV's menu and see what type of audio mode its set on. If it says sap turn on to stereo or mono. If it says stereo, set to mono. Also try to unplug set for 12 to 24 hours.
Posted on Sep 04, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Posted on Jan 12, 2007
  • 19 Answers
SOURCE: female coax connector in tv bad?
Did the cable person take a reading on the signal level at the cable outlet on the wall and did the cable person check the TV setting to make sure they are correct. TV could be set on the wrong channel also.
Posted on Nov 09, 2007
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
Shuttle83
  • 1139 Answers
SOURCE: Blurry/Fuzzy Picture/Double Vision after power outage
Hello stevenkgray and ADIMEN,
I think what has happened is the your TVs are out of focus which could be due to a voltage problem. First I would warn you that this is a problem in the High voltage section of your TV and caution should be taken, in fact I would suggest that if you do not have a background in electronics that you get the TV checked and fix by a qualified TV repair technician. However if you do have a background the next few lines will make sense and you might be able to effect these repairs yourself.
Items needed for troubleshooting:
Schematic Diagram
Multimeter
High Voltage probe (40Kv)
Universal Video Analyzer (UVA)
1) Unplug the TV and take the back off of it
2) connect the UVA to the tuner F connector and setup the UVA to send a test pattern into the TV
3) Power the TV back up and turn to the channel set on the UVA
4) check the anode voltage on the CRT with the HV probe (connected to the Multimeter set to volts and grounded) and compare it to the voltage on the schematic.
5) If the voltage is not right adjust the focus and screen controls on the Integrated High Voltage Transformer (IHVT) to obtain the proper voltage.
6) Check the pattern to see if it is still fuzzy.
If the pattern is still fuzzy you may have to inspect/replace the IHVT and or its associative circuitry.
If you suspect that the IHVT is bad you can perform a ring test on the transformer using the UVA. (The instructions on how to do this are on the UVA quick steps pull out. or the instructions can be looked up on the web.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 04, 2008
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
How to put in video mode without remote
press the menu button and you should have a screen with Picture,channel set,eng/esp/fra, V-chip set up, caption (off).
With picture being highlighted press the volume up button, then press the channel down button until you see game mode, then press volume up for on and volume down for off...
Dec 29, 2011 | Symphonic ST420FF 20" TV
How do you connect a fujitsu p42vca30eh to a BT Vision box? Which cables are needed? Thanks Emma
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions. techpunk_0.jpgtechpunk.jpg
Mar 02, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
I connected the cable box to my LG tv with new HDMI cables and the picture is noticeable smaller than the size of the screen. Before, I had the cable from the wall connected directly to the tv and the...
Your cable box and TV are set to different resolutions. Check the setup on both and make sure everything is the same (ie 720p to 720p or 1080p to 1080p) Make sure your cable box can give you 1080p (Nice set, BTW!!). HDMI is supposed to automatically take care of the settings, but it does not hurt to double-check.
Depending on the manufacturer of the cable box, there may be screen setting for "letterbox" which should be selected.
Some TV channels, when redirected through a cable box, simply will not display full resolution (1080p) programming. Your cable TV provider can tell you which channels are displayed in high resolution.
Finally, make sure your cable provider gave you the correct box. Older boxes are not capable of providing 1080p resolution, and since you own a 1080p set, you deserve nothing less!
Jan 30, 2011 | LG 42LD520 42 in. HD-Ready LCD TV
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I don't see anything on television when i'm playing ps2
What type of TV are you hooking the cables too? Most likely the TV settings will need to changed to one of the following.  TV1 or TV2 using the input button on the remote, or channel 3 or 4.  It depends the set up of the TV
Dec 02, 2008 | Sony PlayStation 2 (PS2) Console
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
The TV has a double vision thing going on. Kinda like its in 3D. The focus or alinment is off.
this happened with my old tv (but it was liek a holographic picture behind the actualy program) it ended up being the normal tv channels, to solve this i just put my normal tv to like channel 6 (nothing waso n that channel) then usedm y cable as normal andi t was fine
Sep 18, 2008 | Televison & Video
May 29, 2008 | Televison & Video
Televison & Video Logo
97 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
