Question about Pitco Frialator 35C Deep Fryer
How do i Clean out the Fire Tubes ? - Pitco Frialator 35C Deep Fryer
I have a Vulcan lg400 propane fryer I have used 4 times at outdoor catering events over the last year yesterday while using it it began what I would call backdrafting. could low propane level in bottle...
It sure did. Never use a gas fryer in low gas pressure for a long time for soot will build up inside the fire tubes.
Check and clean fire tubes, make sure that the flue is not restricted and there should be no air entering the flue.
Regards.
Nov 03, 2013 | Vulcan LG400 Deep Fryer
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
Sep 03, 2013 | American Range Kitchen Appliances - Others
Deep fryer ignites but burner flames will not enter cylinders
Hi there.
Fire tubes may be clogged with soot. Have a technician inspect and clean the fire tubes for soot deposits/ build ups.
Check also if there is no air or ventilation directed on flue as it will push the flames back to the burners.
Regards.
Aug 12, 2013 | DCS Gas Deep Fryer 40 Lbs Double Basket...
Black soot
Hi there.
You have to dismantle the burners on front and flue box at the back to have a good access on fire tubes when cleaning.
Regards.
May 29, 2013 | Kitchen Appliances - Others
My Pitco fryer is shooting large flames out of the door. . . . HELP!
Hi there.
You should inspect the fire tubes, it is a tunnel under the fry tank where the burner flames suppose to travel to heat up the oil. Your fire tubes may be clogged with soot or carbon that's why flames cannot go thru the fire tubes. Fire tubes must be free of soot or carbon deposits.
Soot build up on fire tubes can be prevented by keeping the gas pressure at standard as much as possible, low gas pressure produce yellow flame or poor flame quality and in turn will produce soot.
Also, make sure that no air or ventilation is directed towards the flue riser, otherwise, the same will result, flames rolling back towards the door.
Regards.
Aug 05, 2011 | Pitco Frialator 35C Deep Fryer
The flames on our pitco frialator (40lbs) are not suctioning through the tunnels and is burning an orange flame out the front of the burners instead. We are mobile unit with two 100lb tanks. We clean the...
The flame is restricted to flow inside fire tubes, make sure that all fire tubes are free of soot/ carbon deposit. There should be no air flowing (hood fresh air or any ventilation) or entering the flue box because this will cause the flame to roll back to burners. Also, make sure that the unit receives the right amount of gas pressure as specified in the nameplate, this will surely eliminate carbon build up on fire tubes and burners.
May 27, 2011 | Pitco Frialator SG18S Deep Fryer
My fryer burns with alot of black soot
you need to clean the burners and the fire tubes, remove all carbon deposits.running the unit on low gas pressure results in carbon build up on burners and fire tubes.
Mar 11, 2011 | Pitco Frialator Kitchen Appliances -...
Flames coming out of the exhaust
Clean burners and orifices clean tubes heat tubes and also check the exit to the stack on the deep fat fryer. check pressure. fire off
Dec 18, 2010 | Pitco Frialator PIT40SN Deep Fryer
Last season raypak 2100 heater would light but there was a huge whoosh sound like gas was trapped then finally ignited...this season would not fire...i have heard blocked tubes??? If so how do I...
Thank you for posting your question here on Fixya.com.
Along the manifold there will be several gas ports feeding gas into the burner tray tubes. The tubes are the narrow steel tubes that extend under the heater from the gas line. We use a piece of #12 solid wire and run it in and out of the tubes from under the manifold. Spiders like nesting in the tubes and their silk blocks the gas flow. Once the gas migrates over from further away from the pilot you get the 'whoosh' of ignition. As you clean the tubes and recheck the heater be sure you pay attention to the flame color. Anywhere you see orange flames above a tube you need to shut down and then clean the tube. Orange flame means poor combustion and needs to be fixed to prevent sooting.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 10, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Char broil grill 463631705 lights ok. burns for 1-2 minutes ok. then the fire extends outside the grill box burning between the box and the controls. looking underneath it looks like the fire is following...
there is most likely spider webs inside those gas tubes...you need to clean them out with maybe a wire brush or such. lucky you caught it they can explode sometimes
Mar 07, 2018 | Char-Broil CharBroil 4637318 Grill
Kitchen Appliances - Others Logo
57 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Dan Webster
Dan Webster
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
