Question about Kenmore 7.5 cu. ft. / 212 liter Upright Freezer 24701
Will Freezer run overseas on a transformer?
I am moving to Europe were the power is 220V-50Hz. The specs on the compressor show it will operate at either 115V-60hz or 110V-50hz. Can I safely & efficiently run the freezer using a step down voltage transformer?
    Genius:
  • 1,114 Answers
Step Down Voltage Converters You can use this link to find a converter that should work. There are several other sites as well. You need to get a converter with enough wattage capacity to operate the freezer. I recommend you get one with a somewhat higher wattage rating than the freezer's wattage rating. For instance if the freezer is rated at 700 watts, I would get at least a 1000 watt converter. Good Luck !!! and Bon Voyage !
Posted on Mar 30, 2014
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
  • 117 Answers
SOURCE: freezer fan on compressor off
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: We purchased an 8.8cu.ft. Kenmore chest freezer
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 20, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer coils clean, compressor running,
Yes, it sounds like you are low in charge...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Dec 26, 2010
kachbibi1
  • 979 Answers
SOURCE: Kenmore 8.8 Cu. Ft. Chest Freezer Compressor comes on, but does not cool
I think it is a freon leak.
Posted on Mar 01, 2013
Freezer not running at all
You will need a meter. I wouldn't worry too much about the light unless you realy need it. There is a good chance some moisture has got into the connection and ruined the switch. But if you have no light and no compressor running I would have to check where the main connections are for power to the freezer. If you have power to the receiving end of thempower cord then I would move to the t-stat to see if the contacts are closing when you turn it colder. If they do and you have power through the t-stat then move to the compressor. Pull the little black cover off of the compressor when the power is off for safety reasons, then plug it in and check for incoming power to the compressor. If it is there then you may have a faulty compressor or overload or relay. But that is a slim to nun chance. Probubally the compressor. To check the compressor pull all of the wires off of the compressor remembering where they go( unplug freezer first). Then use the ohm meter and chech across all three terminals. Two terminals will have a low ohm reading 1-5. Then the other will be 5-10 the the last will add up the the others if it woes not then the compressor is shot.
good luck
Apr 08, 2014 | Amana AQF1613TEW Freezer
My chest style freezer will not cool. This unit operated without issue for several years. We moved to a new house and did not want/need to use the unit for a year or so. When I plug it in I can hear a...
its the ptc overload relay on the side of the compressor body,it aids in starting the compressor by momentarily putting your start and run windings in parallel to overcome" locked rotor current",then drops out start windings after unit has come up to operating speed,it also protects the windings if the compressor cant start,they simply unplug off the compressor and the replacement plugs in the same,replace the capacitor connected to this if applicable as this protects the ptc's overload relay contacts
Mar 22, 2011 | Frigidaire FFN15M5H Chest Freezer
Fan runs but the compressor does not run no
While moving the unit you may have jammed or budged the start capacitor which is keeping your unit from turning on. It is located in the back of the unit near the compressor it is oval shaped and silver in color with two wires running out of it. Get the number off of it, go online and search for beverage-air commercial freezer parts. You will need to have the model number to make sure that you get the right parts. Please rate
Jun 03, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Everything is still running but it doesn't get cold
  • Is the thermostat knob turned to the proper setting?
  • Is the compressor motor running? It's a football-sized case with no apparent moving parts on the outside of the freezer at the back near the bottom. Is it humming or making any kind of continuous noise? If it is, but your freezer is still not cooling at all, there may be a serious problem with one or more of these areas:
    • The compressor
    • The condenser
    • The evaporator
    You can't service these yourself. You need to contact a qualified appliance repair technician.
    If the compressor isn't running but you do have power to the freezer, there may be a problem in one or more of these areas:
    • The compressor
    • The overload and relay
    • The defrost timer
  • Jul 16, 2009 | Freezers
    Defrost circut wired hot nuetral ,should this be d/c with a transformer
    Probably uses a Paragon 8145 timer. Wiring as follows
    L1 to 1/2 on timer, L2 to 2 on timer, Defrost Heater to 3 on timer,
    Compressor to 4 on timer, Klixon to X on timer
    May 22, 2009 | Hussmann Commercial Freezer DCCG-8
    GE chest freeze won't get cold
    the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
    domestic freezers do not have low pressure switches that indicate low freon charge.
    Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
    Wont start up
    pretty basic stuff. power cord could be abaded . check to be sure power is reaching the stat with a meter. if it is then check to see if its reaching compressor with a meter, obviously the box is hot so sta t should be calling if power arrives at stat but doesn't come out stat is bad. if it gets to compressor but no run then the compressor start components or the compressor itself are bad. stat has a power in lead and a power out lead. if you check volts between terminals and show 120 the stat is open and bad. if it is set to max cold and failing to send run signalit has to be the stat. if you have power to stat and stat shows no voltage terminal to terminal then its closed and power is not getting to compressor, trace wiring and check .if power is getting to compressor the checjk start cap and relay . if they are good then compressor is bad , usually to expensive to replace.
    Nov 18, 2008 | Freezers
    Freezer is not running even the power receptacle is working
    there are no fuses on a domestic freezer that i have ever seen. there are no fans and there are no traditional freezer coils. so you have only a few things that could be going on. if the temp is way up the thermostat should sense hot and close and send power to the compressor and it should run. you can do one of two things . find the thermostat inside the freezer usually . gently remove cover and check incoming terminal and outgoing terminal. if you show 120 volts its open and the stats bad. if you don't show 120 volts between terminal connections then its closed and the compressor is failing to start. if power is coming into the stat when checked to ground then go to compressor and see if there are starting components . they are a start capacitor and a START RELAY AND PERHAPS A OVER LOAD . SEE IF POWER IS ARRIVING AT THE COMPRESSOR. IF SO CHECK THE MICROFARED OUTPUT OF THEcapacitor . you need within 10 percent of the rated value. also you can gently remove the overload , a little plastic disc and look on the bottom side and see if its cracked or burned looking. an amp probe on the compressor will tell you what amps it pulls if it trys to fire up . 6 to 10 is good 30 to 50 is mechanically locked up and then the overload trips. if compressor is ice cold to touch then your not getting power to the compressor and its not trying to run. if its hot to the touch thens its trying but start caps weak , or its locked up. most domestic freezers are not worth the cost of a new compresssor anymore. good luck
    Oct 31, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
    check light inside .on? you got power. check compressor in back on? if no then you probably have a bad stat. open door and look inside for numbered dial. turn max hot to max cold back and forth. if compressor comes on you need a new stat probably. remember only a stat a compressor on these units. if its hot stat should send power to compressor. if power is arriving at compressor and not running then start relay and or start cap are probably bad. but if compressor is running and still no cool then your probably out of freon. unfortunitly these boxes are made with steel tubing in the cabinets. when you move them lots of times the tubing rusts and ruptures. then your all done. new freezer time. they are sealed to the point there are not even a place to apply gages to check charge. you can gently remove power and then stat and jump thermomstat to take it out of equation and if compressor runs you need a new stat. constant power comes in one side of the stat and when the sensing tube is heated it closes the points to the outlet side and puts power to the compressor. there may also be a ground wire usually green be sure to observe which two are power in and power out. usually side by side. good luck
    Oct 25, 2008 | Freezers
    ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
    It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
    Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
    Kenmore 7.5 cu. ft. / 212 liter Upright Freezer 24701 Logo
    99 people viewed this question
    Top Kenmore Freezers Experts
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    christian nielsen
    Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
