Question about Emerson Televison & Video
Power light not on
Tv front light not illuminated.
  • Emerson Master
  • 3,320 Answers
It's dead. Broken. Failed. Done. There, I answered all your posts.
Take it to a repair shop.
Posted on Mar 31, 2014
How can I get my TV to come on? Because I'm not sure what the lights mean on the front panel
you need to describe whether the lights on the front panel are illuminating in a certain pattern and the make and model of your tv set
Jun 30, 2015 | Televison & Video
Sanyo DP42849 has no power lights illuminated
Sounds like a power supply failure, but you will need to get it diagnosed to be sure.
Oct 31, 2012 | Sanyo DP42849 42 in. HDTV
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
50px1d-uc When I try to turn it on, the red power light blinks, I hear a click, then the light turns amber then back to red. Usually I'd hear the click then it would turn green and the tv would work...
I came across this in a manual
-Without CableCARDTM : Illuminates red in
standby mode, Illuminates green when the
TV is turned on.
-Inserting the CableCARDTM : Illuminates
orange in standby mode, Illuminates green
when the TV is turned on....
You might want to check your cable card. It seems to mimic your problem. Try taking the card out and gently clean, with a dry cloth, the contacts/strip. Then take some "canned air" and blow out the card socket from the side to dislodge any accumulated debris.
Oct 13, 2011 | LG 50PX1D 50 in. Plasma Television
TV won't come on using romote or controls on side of TV. Should there be a light on permanently on the front of the TV, because there isn't.
Yes, there'e usually a standby indicator LED that will illuminate when the TV is plugged in and not yet turned on. Flat panel TV's like these are notorious for bad power supplies and sometimes bad main boards. Try unplugging everything and maybe try a different outlet, or use something like a lamp to plug into the TV's current outlet (to verify power to the outlet). Might be time to call a shop however.
Jun 08, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Mitsubishi ws-73711 turns on (I see a green power light) then off
press and hold 'device ' and 'menu' buttons on front of tv until the power light starts to blink out an error code . It will blink a few then pause and....repeat.. . Count the blinks. It is giving a two digit error code and repeating it 3 or 4 times. 22=low voltage short detected usually caused by the convergenge amp I.C. .12=normal
Oct 03, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Televison & Video Logo
20 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
