Question about Canon MP18D II Basic Calculator
Repairing a canon electric calculator
S symbol on visual display makes the calculator to give no response.
Infinity Symbol
Very few graphing calculators can display the infinity symbol
. Most calculators have no use for it. In all likelihood yours too.
Aug 29, 2014 | Casio Office Equipment & Supplies
It wont give me the value when i multiply like 6 x pi
Your calculator may be able to use the symbol Pi. If it gives you a result with Pi, you should convert it to a decimal approximation. There must be a key to convert.
Nov 12, 2013 | Canon F-719SG Green Scientific Calculator...
Press numbers display syntax error how solve a problem?
The order in which you are entering numbers and operations is not correct. For example, if you enter 5++2 most calculators will flag this as a syntax error.
On some calculators you calculate square roots as follows: 25 [SQRT]= gives 5. That is the correct syntax for this type of calculators.
For the newer ones you press the SQRT key and see displayed the square root symbol followed by a left parenthesis. You enter the number, close the right parenthesis, then =. If you do not respect the order you get a syntax error.
I cannot say more because I have no idea what you were trying to do, and more importantly, I do not know the make and model of the calculator.
Oct 28, 2013 | Office Equipment & Supplies
Canon P170-DH 11 won't add correctly
If you don't know about calculator electroncs, you don't have own means to repair it so take it to a repair technician, ask a diagnosis and evaluate if it's worth to repair your calculatoe or dispose of it.
Mar 26, 2013 | Canon P170-DH Printing Calculator
Hi, there's a red icon/symbol flashing on the display...it looks like a rectangular symbol with a arrow... I think it's related to the eject-button...
The flashing icon says there is no tape in the camera. If that's incorrect then there is a problem in the cameras tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 14, 2010 | Canon MV600 Mini DV Digital Camcorder
Ti-83 plus decimal help?
Press MODE, then navigate down to the display setting and select FIX and whatever number of digits you want to the right of the decimal point.
Feb 10, 2010 | Texas Instruments TI-83 Plus Calculator
MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Sep 08, 2009 | Casio MS-80TV Scientific Calculator
My Canon P23-DH calculator is printing out weird symbols
I also have a Canon P23-DH 111 that is printing strange symbols. This has happened after an electrical storm.
I contacted Canon Support and they verified that the board inside has been corrupted by a power surge.
I now have a new Canon P23-DH V and I invested in a surge protector.
My grandaughter is playing with the old machine.
Mar 09, 2009 | Canon P23-DH Calculator
SYMBOL PDT61XX
It is simple, Symbol PDT devices was designed to Operates with eMbedded Visual Basic and eMbedded Visual C++ both with MFC and without MFC.
If you know Visual Basic 6.0, I can help you to solved your issue. Please give me chat session if you are interested.
Best regards,
Philip
Oct 02, 2007 | Symbol PDT6842-NIS632EU Portable Data...
Canon MP18D II Basic Calculator Logo
61 people viewed this question
old marine
old marine
