Question about Marshall MG100HDFX 100-Watt Amplifier Head
I have an MG 100hdfx everything works fine till I plug in foot-switch, nothing happens when stepping on either switch. I've lifted the front of the head to about a 45' angle and the foot-switch activates Crunch with either switch as long as my foot remains on either of the switches, having that happen tells me something is loose but I'm not sure if its the jack or something else, also headphones do not work when plugged in and sound still comes from speakers, could they be coupled with the foot-switch problem?
  • Bob Stato
    Bob Stato Apr 23, 2014
    Thanks Robert, I checked and the ground wire broke on the plug end of the footswitch, fixed that but I still have to hold down switch when I let off it will not hold and goes back to original channel, any ideas ?
  • Robert Jenkins Apr 24, 2014
    it sounds like, again, a severed wire. or the switch itself has gone bad. check the connections at the switch and the end where it plugs in
    Scholar:
  • 78 Answers
It sounds like something internal on the foot switch is shorting out (or a lead wire has come off) or some where in that line , it has been severed. you can check continuity with an ohm meter. butfirst open the foot switch and just give it a visual to see if any leads are severed. you may just need to solder it back. - foot pedals get alot of winding up and unwinding. its common for something to disconnect. that would explain all the issues your having. good luck
Posted on Apr 20, 2014
bob_computer
  • 3153 Answers
SOURCE: marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Posted on Sep 09, 2009
Testimonial: "that sounds like the best way to do it..will just take fan to computer shop and try and get a replacement...thanks for the assistance"
  • 5603 Answers
SOURCE: by mistake i plugged the speaker jacks from
If you connected an external speaker plug from one into the same type plug on another amp, you have driven signals backward into the amp that was off... NOT into the speaker in that unit.
The usual result is blown parts in the amp that is off.
Some amps have their own speaker cable that you can unplug to connect to another amp and that is fairly safe. NEVER run an amp without a speaker load on it.
Posted on Feb 21, 2010
AndroidLVR
  • 31 Answers
SOURCE: Marshall MG50 DFX amp line out/headphones not working
Well, your problem isn't very descriptive to help troubleshoot online, but first question would be; are you using the correct size jack? The second would be have they worked before? If the answer is yes to both questions, then the problem might be the jack itself on your amp. There is a prong inside the headphone line that hugs the plug to your phones. If the prong has loosened enough where the connection is poor or not at all, you will not get any sound. If the headphone jack has NEVER worked before, than it sound like a wiring issue on your board somewhere. If you are not familiar with a soldering gun, then I would take your amp in to get it fixed. should be a minor quick fix costing anywhere between $15-$30 to have a shop do it. Hope this helps. (also try different headphones if you haven't already. Could be a bad pair)
Posted on Mar 09, 2010
SOURCE: the fan on the back of my marshall mg 100HDFX is
You can either oil it up OR replace it for around 20$
Both ways involve removing the amp from the casing by unscrewing the 6 screws on top and sliding it out and then getting the fan out
locate the fan; locate the 4 outside screw covers that are next to the fan grill screws and pop them open. Remove the four screws that are under those plastic covers. The fan should separate. Take Fan out and remember how it was in there.
To oil: lift the sticker and locate the rubber plunger in the middle of the fan; remove it. Then, put ONE drop of regular 3-1oil NOT-wd-40, pb blaster or bike lube. re-assemble
To replace: just unplug old fan and then replace with new fan. I recommend replacing the fan when it gets to the point of bearing noise because oil doesn't always fix this.
Posted on Oct 06, 2010
  • 5603 Answers
SOURCE: I have a MG50DFX and
This is likely a bad switch contact in the headphone jack... they are really poor quality in most amps... plastic case and EASILY damaged by side forces on the jack. REplacement is the solution.
Posted on Nov 30, 2010
Fix
Replace the internal micro switch or just by a new pedal
May 08, 2013 | Casio SP3 Sustain Pedal
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
Marshall MG30FX loud tapping sound in time with delay even when no guitar plugged in and effects turned off
Hi J Wade. I'm Dave P. I'm not a guitar amp expert or technician but I've been using amps and effects for 35 years and there are a couple things I can suggest.
That kind of periodic noise/switch noise can be a symptom of having the polarity of the amp reversed. If your amp has a 3-position OFF/ground switch, try reversing the ground. If it doesn't, take the plug and turn it around. Just don't get near a microphone unless you're sure your amp is grounded the same as the P.A. It could fry your lips off.
Dirty switches to that too. You said the noise is in time with the delay's tap time which is set by a foot switch. If tapping that switch the first time generates a pop, the delay may have catch it and is repeating it. Turn off the amp, remove the delay foot switch and turn it back on. Still noisy? If not, give the foot switch a good cleaning.
When you turn the EFFECTS knob up, is it scratchy? Might need the potentiometer cleaned. What happens when you specifically turn the DELAY level down all the way while using the other effects? Noise still there?
That's all I've got. Hopefully, it was helpful. Don't wrack your brain over this too much. There could very well be an internal problem with your amp that will require a trip to the shop. You don't want to open it up yourself. Rock on but be safe.
Dave P.
Aug 22, 2012 | Marshall Amplification Marshall MG30FX...
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
The fan on the back of my marshall mg 100HDFX is making a weird noise when i first turn it on. It eventually sounds normal after about three minutes. Im not sure what i need to do?
Oct 02, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
My problem is that the clean channel doesn't work. The OD1/OD2 channel works just fine but I'm not getting any sound out of the clean channel... any ideas?
Here is the schematic:http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf There are a few possibilities.The jack for the footswitch for channel changing JS1 might be faulty. Zener diodes 1 and/or 2 might be faulty. Switch 2 may be defective. TR1 might be defective. IC 4 or 5 might be defective.Start with the channel switching circuitry testing in the order I gave you. Check the actual clean channel circuitry to see if you actually have a clean channel anymore. Before you do any of this make sure you know enough about troubleshooting and have at least a good VOM and are familiar with safety procedures. The filter capacitors in this amp store enough charge to kill you. A cheat to partially discharge them without damaging the amp is to unplug it from the wall while it is hooked up to the speaker cab you are using while it is on at a very low volume with a guitar cord plugged in. Make sure you use exact replacement parts if you tackle this. They don't have to be from Marshall, they just have to be exact electronic equivalents from a quality manufacturer installed correctly. I would recommend that if you have no experience or are at all unsure of the repair to take it to a Marshall dealer to have it done. Please rate me if this helps.
Nov 29, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall mg 100hdfx fan
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Feedback noise when overdrive is on
it could be your guitar pickups. try using another guitar or getting your pickups waxed at your local music store. also if your playing in a small room kind of loud, or if your using single coil pickups (like fender statocaster pickups) you will definitely get a feedback noise. if that does not work let me know.
May 10, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Digitech RP 90 foot switch is not working
I removed the back cover, unscrewed the two (of 4) screws holding down the circuit board, replaced them again, and it worked fine.
Jan 11, 2009 | Music
Guitar amp channel switch repair
Replace the switch. You gave no make/model number for your amp but if it has a jack for foot pedal operation of clean/dist function then try that. (on most amps) it will switch in spite of a bad front panel switch.
Dec 21, 2008 | Music
Marshall MG100HDFX 100-Watt Amplifier Head Logo
83 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
