Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer won't do anything. It won't fill or spin. Nothing!!
I finished washing a load, then put a new one in but nothing happened. I checked the plug and it was all good not to mention the dryer was still working. I tried putting it on a spin cycle and holding down the lid button and still nothing. I am thinking it is electrical of some sort.
  • 1 more comment
  • Joe Hawkins Apr 19, 2014
    If it is the timer dial you can take a multimeter and see if you have a solid circuit by checking the ohms readings. When it should be on you should get the same reading almost as you get just touching the two meter leads together. If not then you are not getting contact inside the dial so no electricity can flow through. That tells you if it is the problem or not. I personally would start with the power cord. Sometimes it is the plug in part of the power cord that goes out. It is a simple fix. You can either replace the cord or just the end that is bad if it is the end. Start with the simplest first.
    Since the dryer is still working the cord connection would be the place to start on the power cord. It is inside the back panel. Might even just be loose? You can also first check with the plug in wires on the dial to make sure the connections haven't got corrosion on them. Then do the multimeter check on the dial if they are not corroded.
    Concerning the lid switch. You need a multimeter to check it also. You can take it out of the circuit then use the ohms meter to see if when you push it down the meter read about the same as when you touch the leads together. If it does the switch is still working. If it doesn't you have found your problem.
  • 3 Answers
If nothing is working at all it is probably the timer switch (dial you turn) they die. Not too expensive to fix. If you are comfortable with tools you can very likely do it your self. I know this because I paid a service to do it. When he was done, I went - Huh, that's all there is to it? It is just above Lego. If I remember correctly it took him less than 15 minutes to do it but I of course had to pay the minimum service call charge.
So just find a YouTube video for changing timers and you'll see what I mean.
Of course if it is not the timer you just wasted time and money.
I don't know how to confirm if it is the timer that is broken. Perhaps there is a diagnostic video....
Good luck
B
Posted on Apr 15, 2014
ngfam1
  • 639 Answers
SOURCE: whirlpool washer not spinning or draining
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
SOURCE: Washer Stuck in Cycle
I checked the lid switch and nothing appears to be broken (cracked plastic). What exactly should I be looking for? Also during the agitator cycle I opened the lid and the washer stopped working. Does that mean that the lid switch is working?
Posted on Jan 14, 2008
donnastr
  • 10 Answers
SOURCE: Whirlpool washing machine power button won't turn the machine on
defective timmer
Posted on Oct 08, 2008
david04928
  • 102 Answers
SOURCE: My 4 year old Whirlpool Ultimate Care washer was
Sounds like the belt broke and probably need replacing or the motor is shot.
Posted on Mar 14, 2009
garing
  • 998 Answers
SOURCE: whirlpool duet dryer gew9250plo dryer will not turn on
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram heaver red wire for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Posted on Aug 14, 2009
My washer wont turn on at all, wont fill up,spin or rinse on any setting
it sounds to me the lid switch problem. when it fails nothing works on some models
Dec 27, 2015 | Westinghouse WWS833ES Super Capacity Top...
Washer fills up then nothing else happens will not wash or spin it will fill and empty
if u hear the motor running after it fills then u need a motor coupling
Jul 21, 2009 | Kenmore 44072 Front Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Wont finish
did you re-fit the belt? if you did it could be a fault with the motor brushes.
REMEMBER TO SWITCH OFF THE POWER BEORE CHECKING :)
Nov 03, 2007 | Indesit W 123 Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Washer
Does washer spin without any clothes or water, try 'spin' only. If no, then u might have a loose connection to the motor. After u disconnect from the wall socket, see behind to see if all connections are ok. Do not over-load your machine, it could trip a switch which will stall things. Suggestions...
May 01, 2007 | Kenmore 24872 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
