Question about Maax Acrylic Base for Shower - 102623
Chipped shower base
Our shower base has a chip. How should we fix it?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Supply stores, lowes, home depot sell two part epoxy for fixing this. Although epoxy says for porcelain it can be used on other types of materials.
Posted on May 06, 2014
2 Suggested Answers
  • 414 Answers
SOURCE: I dropped some tile on
They sell a white marine epoxy which may be suitable for the repair you describe. If I
needed to sand it afterward I would use 2000 grit wet dry to feather the edges. Hope this
helps. The epoxy is sold at home depot in the paint department. You could also check
with someone who does gel coat repairs on boats through your local marine dealer.
Posted on Feb 27, 2011
I dropped some tile on the shower base while I was tiling. It compressed and chipped the edge. No leak that I can tell but it looks bad. Can I repair this?
Feb 26, 2011 | Maax Acrylic Base for Shower - 102623
Tip
"double vision" caused by bad solder points on convergence chips (check before...
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able to smack the side of the tv or tap the heat sink for the chips and it corrects the problem than chances are the chips are fine butone or more of the solder points are bad. When I looked at the joints for the chips I noticed hairline cracks around the base of the joint. Re-soldering the joints for the convergence chips solved my problem.
on Jun 02, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Can i install centrino deu processor to dell inspiron 700m ?
Yes, you should be able to upgrade the CPU. The 700m uses a Pentium M CPU running at a 400MHz FSB (or Celeron M at 400MHz FSB). It is compatible with both the old 'Banias' based chip (1MB L2 cache, up to a maximum 1.7GHz) as well as the 'Dothan' based chip (2MB L2 cache, up to a maximum 2.1GHz). All new orders ship with the newer and superior Dothan based chips now (unless the Celeron is chosen), and I suggest you stick to that path when upgrading... the only advantage of the Banias based chips are lower power consumption at the low speedstep setting coming at the cost of some performance. Since these are intended to be portable semi-desktop replacements the more powerful Dothans are preferred.
Don't forget some Thermal paste when installing a new CPU or you may encounter some heat issues which can cause serious damage.
Sep 03, 2010 | Dell Inspiron 700M Notebook
The black coating on the handle of our grohe kitchen faucet was chipping so Grohe sent us a new handle. We have tried all sorts of muscle power and tools and simply cannot get the old one to come off. Is...
Is there a little emblem or similar in center of handle that pops out to expose a screw or allen key style screw? Also check around base of handle,(almost standing on your head) for a n allen screw head as well, or any area that looks like it might pop out .
Dec 31, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
I am unable to use other SIM plz tell me unlock coad.
if its network based phone like u got it with an airtel connection or somethin... u need to get a chip fixed in it.. it will cost around rs.200 to put that chip, then u can use any sim..
Aug 27, 2009 | Lands Phones
?blown bulb
do you hear a high pitched whir or chirping? the whir is normal. the chirping is the colorwheel not syncing with the dmd chip. this will cause that image distortion. if the colorwheel is fine, then it's the dmd chip of the chip pcb that needs reseating or replacing.
Feb 20, 2009 | InFocus X1 Multimedia Projector
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
1800FP monitor ICE chip
you NEED the EXACT ICE CHIP, not just any old chip. They make millions of IC'S, you can get a reman power supply on ebay for cheap from ressurectek, tell him jimmyvisthekey sent you. Later.
Jul 06, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Maax Acrylic Base for Shower - 102623 Logo
100 people viewed this question
Top Maax Plumbing Experts
Donni Steen
Steve
obsteiner
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
