The power blinks red and stops, the monitor does not come on
Monitor does not come on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
I need more information for your model (monitor).
But when it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
Posted on Apr 04, 2014
Why is the 7 red blinks of *****
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Panasonic TCP65VT50 65 in. 3D Smart Plasma...
Hp w2408h monitor flashing red green black blue white
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
I have a lcd monitor citizen tv set LT2010 , suddenly it doesnt work anymore and there is a blinking red light, i unplugged and nothing work.. please help me
Monitor power supply board have dead components parts call capactiors most likely.The power supply board that the board where the power a/c cord plug into it.U have all the tools and know basic electronic also can do basic soldering works?Yes,take it aparts and check the power supply board carefully and replaced all the dying or dead capacitors components capacitors parts,these dying capacitors parts dying are alway bulges and puffing up onto it tops.Replacing all the dying and dead capacitors that are having bulges or puffing up onto it tops,monitor will have red power light indicator LED light stable again and will stop blinking.The monitor will work again.
May 11, 2011 | Televison & Video
I received a corrupt file message and for some reason i decided to restart my pc. the green power light comes on as well as the red light which blinks. after a few seconds the red light stops and the...
The red light is the indicator for the HDD activity , since it stop it's clear that the corrupted files were essential ones, that should have been loaded during the Windows boot process.
Your only thing left to do is to reinstall. If you're lucky you can get away with a Repair install, try it first.
Jun 22, 2010 | Computers & Internet
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
On my syntax olevia lt20hvk monitor the power light will not stop blinking red and will not turn on. What do I do?
The PSU (power supply unit) seems gone as the red blinking led means that current is reaching the PSU but it is not being supplied ahead of it. Please replace the psu with exactly the same specs.
Nov 16, 2009 | Computers & Internet
Power light blinks red, green and off. No picture
Is there another monitor input on the back of you computer? Sometimes this happens when your graphics card is not compatible so it is best to try another one. If you have another one plug it in there first. If you don't try the monitor on a friends computer. If it still does the same thing, it may be a manufacturer defect and may need repair.
Nov 06, 2009 | Planar PL1911M-BK (Black) 19" LCD Monitor
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
