Question about GE GSD3200J Dishwasher
Not coming on
When I start it will not come on checked fuses and power all ok.
  • 85 Answers
Do you get any lights?
Posted on Mar 31, 2014
Fog lights not working
Hi, first start checking the globes, are ok, check and test if there power coming to the fog globes, check the fuses and your wiring, and last one check your switch on/off if making contact to supply power to the fog light.
Dec 12, 2013 | Cars & Trucks
My dome lights and my odometer lights are out and wont come on when i start my car. What can i do to fix this?
first and easiest to check are the bulbs, do this with a meter since they are so easily misdiagnosed , if that checks out ok, look for a bad ground,, use the meter to see if power is even getting to the sockets, if not,, look for an offending fuse thats blown, if fuses check out ok, your going to have to backtrack the power wire until you find the bad connection or break in the wire
Jul 02, 2011 | 2003 Kia Spectra
1997 GMC Savana 5.7 L conversion van. Cranks but wont start
look under the hood on the right side where your brake fluid is..There is a black box to the farest right of the brake fluid. take off the lid to this box were you will find fuses..Reach in and feel the fuses to see if any are loose.The largest fuses in the front, push down on those and then try to start it up..Take them out look at them make sure there ok if this dont work..they the one bad might need to be replaced..
Nov 17, 2009 | GMC Savanna Cars & Trucks
No tail ligths and brakes ligths is it a fuse?
Maybe, could be a broken wire that supplies power to the bulbs more likely, if you find all fuses OK.
Oct 01, 2009 | 1998 Buick LeSabre
Power mirrors will not work have checked all fuses. where is wiring harness for power mirrors?
Hi mate, Before you start checking the wiring.
Check the switch first, they can be faulty.
If they are ok, then check if the current is coming from the fuse to the switch. And if that fails have you wiring checked last.
I hope ths helped?
Jul 29, 2009 | 2002 Pontiac Montana
Hi i have a 1998 jaguar xj sport v8 the problem is i went to start it the ignation lights came on and then went of now i have nothing i checked the battery it is ok i checked the main fuses in the boot...
check all leads coming from the battery with an ohm meter, should read zero, no resistance, make sure you do this test with the battery dis-conected otherwise you can burn out the meter or the fuse in the meter. if you need more help get back to me
May 15, 2009 | 1987 Jaguar XJ6
Parking lights will not come on. I check the fuses and its ok.
Hello
Welcome.
I would check the head light switch see if we have power in to the switch
from there see if there is power out. sounds like a bad switch if the park lamp relay is ok
RD
Jan 12, 2009 | 2003 Dodge Ram Maxi
Go to start and needles on dash bounce as if they have a pulse
Hi...
I read your problem.
Is there a few step to diagnostic or try to fix your car.
Follow this simple steps.
Inspect the RALAY " Starter relay # 47. or interchange with other one just for testing.
1- Check the Fuse " IGN E Fuse number 22 " 10amp. on under hood fuse BOX fron Neutro swicth
And power to the power to the Neutro safetly switch.
2-- Check the Fuse " CRANK fuse # 17 10amp. Under hood fuse box. 12v. from Ignition switch
3- check the fuse " IGN A fuse # 34 40 amp. under hodd fuse box. Constant 12v. to relay.
With ignition switch in ON position.
Crank Fuse only when you try to start. If no power 12v. come when trying to start.
REmove the steering column covers. to get axces to the IGNITION SWITCH.
Trying to start check if 12 v on the YELLOW wire exist. if not. Check if there a 12v on the RED wire
If not Inspect FUSE # 34.
But if there a power on the red wire But not ON yellow wire Trying to start.
Just REPLACE THE IGNITION SWITCH. Electrical part.
Check the NEUTRO SAFETLY SWITCH. connector under the car. Repair as need.
CHeck the BACK-UP lights, some times come damaged making a short on the Neutro safetly switch. ...
OK.. I hope this help on your problem.
If you need more information letme know.
I'm a Mechanic and have all the information for repair vehicles.
Thank you for use fixya....
Sep 13, 2008 | 2002 GMC Envoy
Cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Feb 18, 2008 | Kitchen Ranges
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
