Question about Copystar CS-2050 All-In-One Printer
Copystar cs-2050 scanner
I want to setup the scanner, but the button doesn't do anything and the programming doesn't have the "scan default" option available
    Problem Solver:
  • 43 Answers
The 2050 scanner card is an option, it is located on right side above the
network card. if you have one you will need to run a separate cable connection to a switch or router. if you are scanning to a file on computer, you will need to download a program called scanner file utility.the scanner will only work on a network connection.
Posted on Mar 31, 2014
  • 126 Answers
SOURCE: Copystar CS-1810
You need to run sim U163 to reset fixing heater problems. Press and hold stop, start, and left exposure key in that order. Release and press stop again. Use zoom keys to enter 163, press start. Exit the mode by entering 001 and start, or power off/on.
Posted on Jan 16, 2009
EmmettPinger
  • 63 Answers
SOURCE: copystar cs 305 scanner is not connecting to computer
I do not know much about the situation but, I'll give it a try. First turn the pwr off to the scanner and try to ping agian just to make sure you are not trying to use an ip adress that is aleady being used. You should not recieve a responce untill you turn the power back on but, if you do get a reponce while the scanner is off change the ip adress on the scanner. Next if that did not help, you will need a correct path to your computer from the scanner like example( \\server\public\scans ) next you will need a username and password to gain access to the shared folder..
Posted on May 03, 2009
krizanto81
  • 65 Answers
SOURCE: how to put an IP address on the CopyStar CS-1820 printer
putting an ip to 1820, just go to system menu, scroll down look for the network setting, you will find ip address, then fill it up.
Posted on Jun 27, 2009
n25an
  • 622 Answers
SOURCE: Unrecognizable error code
call kyocera support... you are having a serious problem
Posted on Dec 26, 2009
n25an
  • 622 Answers
SOURCE: Copystar CS-2550 Set up add'l scan folders - need to reset psswrd
try 6482... or call kyocera support or call a kyocera service tech
Kyocera 2050 locks up while scanning
you are filling the memory up split the scan into smaller batches
Apr 18, 2014 | Kyocera COPYSTAR CS-2050 Printer
Copystar CS-2050 cutting off edges when copying or scanning
Check your default paper size. It may have been set for A5.
Apr 07, 2014 | Copystar CS-2050 All-In-One Printer
FTP Privileged Port Bounce Scan is a security problem
I would need more information. I have figured out several deep issues regarding nessus. Such as how to remediate Microsoft Advisory 2974294. Search for MRT.EXE and delete it.
Dec 16, 2013 | Copystar CS-2050 All-In-One Printer
Kyocera CS-C2525 won't scan
Do you have the option installed on you copier??? Also, there is another ether connector for scanning. If it is installed it is right above the print PCB.
May 22, 2012 | Kyocera Copystar CS-5035 Copier
My kyocera is not letting me scan.
Go to www.gfbm.net on the service page / self help for instructions on setup.
Dec 08, 2010 | Kyocera COPYSTAR CS-2050 Printer
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
Kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Mar 04, 2009 | Kyocera Mita KM-2050 Printer
Reset Scanner Password for Copystar CS-1650
yes you can !
turn OFF the copier and unplug the power cord and the network cables!! Take off the scanner board - there is a jumper to reset the scanning system to default factory settings. Install the scanning system and power the copier. Wait till is Ready to Copy + 2 minutes. turn OFF and unplug the power cable, restore the jumper on the scanning system board. Put it back and power up.
Dec 16, 2008 | Kyocera Copystar CS-1820 Black and White...
Copystar CS-2050 All-In-One Printer Logo
108 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
