Question about Hilti TE 70 Hammer Drill Performance Package
Need to know the order of the plug wires that goes to the ignition plug that goes in the new plug
Back of ignition
Fiat palio ignition timing
its marked on the coil
and on the valve cover
its a wasted spark system.
the coil is marked (if not sub coil)
2314
1 goes to 1 front cylinder spark.
2 goes to 2.
3 to 3
4 to 4 rear spark.
the ecu knows the order but the wires MUST be right.
#1 spark is closest to front engine pulley, (belt side)
#4 is rear.
Jul 15, 2014 | 2005 Fiat Palio
How to plug the top wire back in on the ignition switch
You have damaged the hard shell of the connector where that wire goes, you now need to install a new repair connector.
Jul 18, 2012 | 2001 Chevrolet Impala
Why is my 1992 ford festiva firing in the order 1-2-3-4 and not 1-3-4-2?
Your order is wrong, and you need to switch the wires around on the top of the distributor. First pull the distributor cap off to find direction of rotation (some distributors turn clockwise, and some turn counterclockwise). Watch the rotor, the black bar on top of distributor shaft, and note it's direction of travel while someone bumps the starter over with the ignition switch. Now you can put the dist. cap back on, and arrange the spark plug wires in order 1-3-4-2. Leave number 1 in place, if it is marked as 1 on the cap. The plug wires can be pulled out of the raised terminals in the distributor cap for setting them in order. Just be careful of pulling too ******* the wires, you can cause them to break internally. Twist them back and forth first to loosen them, and gently pull them out, using the plug wire's rubber boot if possible to pull on them.
If it is easier to pull the sparkplug wires off the spark plug, rather than the distributor cap, you could set the order that way. Just need to know the direction of rotor travel. Number1 will go to cylinder 1, and next in order will be number 3, following direction of rotation, so that wire goes to cylinder 3, and on to 4, then 2.
Post back if you need more help. Good luck.
Jul 02, 2012 | 1992 Ford Festiva
2000 ford mustang code 453 and missfire cyl 5 where is the cyl
a haynes manual from a parts place will show you--or chec the condition of each plug wire-if one looks bad or falls apart--probly need to get all new wires /plugs
Dec 18, 2010 | 2000 Ford Mustang
I took of*** my spark plug wires working on my small block 350 pickup and I don't remember the the firing order to put the new wires back on. Is there a diagram anywhere or is it even that difficult to...
Next time number each lead before you remove it and no. the dissy cap as well
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
See the diagram; Click to open a printable larger image in a new window. The firing order starts with the number one cylinder. We would connect the number one spark plug wire to the distributor cap terminal in the 6:30 position. distributor.pngSince the next cylinder in the firing order is 8 (passenger side rear), we connect the number 8 spark plug wire to the next distributor cap terminal (approximately 7:30 position) in the clockwise direction from number one. You need to be sure you continue the firing order in the clockwise direction around the chevy small block distributor cap from the last installed spark plug wire. Setting the rest of the firing order is just a matter of repetition. Be sure to count the spark plugs from front to back on each side of the motor to identify the correct cylinder number in the firing order.
Jun 21, 2010 | Cars & Trucks
Whats the order the spark wire goes?
I do not know if you have the 1.8L, 2.0L, or 2.8L; however I have included all three below.
For the 1.8L AND 2.0L:
Fire Order:
1-3-4-2
Cylinders:
.......(back)
1.....2......3......4
......(front)
Distributor:
....(back)
(+)..1
2.........3
......4..(+)-screw
...(front)
For the 2.8L:
Firing Order:
1-5-3-6-2-4
Cylinders:
........(back)
1.......3........5
....2........4........6 (bank offset)
........(front)
Ignition Coil Connections:
(back)
2...5
4...3
6...1
Oct 16, 2009 | 1997 Volkswagen Jetta
Spark plug wires correctly installed on pontiac sunfire
you need to know the firing order and then where #1 plug wire goes. Need a shop manual.
Distributor or distributorless ignition?
Feb 21, 2009 | 2003 Pontiac Sunfire
Ignition Wiring
To my knowledge, firing order is 1-8-4-3-6-5-7-2 clockwise on the distributor cap with the Number 1 post pointed towards the Number 1 cylinder. The cylinders are numbered 1-3-5-7 (front towards the back) driver side while the passenger side/bank are numbered 2-4-6-8 (likewise front to back).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 04, 2008 | 1993 Chevrolet K1500
Hilti TE 70 Hammer Drill Performance Package Logo
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
