Installing IDE drive in Bytecc ME-350V4 (no manual supplied)
There is a power supply (4 wire) connector loose inside the case that seems to be a power supply for the IDE drive but no obvious place to connect it. Also sitting lose is a ribbon data cable with no indication of which way around it is to be installed. There are two cables connected to the circuit board, both labelled SATA... but that is not what I am trying to use. I have been unable to find any installation documentation on the internet.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
It sounds from your description you change out some hardware and left the wire behind. IDE is consider to be old technology replaced by SATA. Unless it broken don't play with the wire, you could either leave the wire handing loose or just remove the ide ribbon wire, either way it won't hurt the computer.
Posted on Mar 30, 2014
  • 277 Answers
SOURCE: ide issues
create partiion and format hard drive.
Posted on Mar 07, 2008
pankaj_dic
  • 1252 Answers
SOURCE: A acquaintance gave me a
yes you can connect sata hard drive, but first you have to install a pci sata card, into the pci slot of *********** board
if you like the solution please rate it
Posted on Oct 14, 2008
SOURCE: connecting a 2nd internal hard drive
i ned driver for pc model dell celeron gx100
Posted on Feb 18, 2009
bahratt
  • 561 Answers
SOURCE: I have just installed a samsung trudirect dvd
You will need a Sata Power Connector: see http://www.endpcnoise.com/cgi-bin/e/std/sku=SATA_power for example
Posted on Jan 10, 2010
Testimonial: "thanks "
SOURCE: Dell Dimension 5100 will not power up. Was
Have you checked your monitor? Try your monitor on another PC and check it is OK. Once you change the MB battery you effectively "Kill" the PC, as all the settings in the BIOS are removed and must be reprogrammed. You must enter the BIOS, and select "Default" setup and then reboot, you must do this regardless of what else is done first.(A bit hard when you can't see anything" You say... "tried different power switch and ribbon cable connector" (sic) exactly what "Ribbon cable/Power switch"? Anyway as said check monitor, if it is OK, we will proceed from there, then, you must check your video card, test it in another machine, if possible, to see if thats OK, if it is OK, then it is now likely that you may have a Mother board problem. If you can, try another Video card to see if you get Video on screen. see we need to establish "Known Good" items, once we know whats what, we can then go on. Now if any of these things tested are faulty, Monitor, Video card, obviously replace them, however IF they are NOT faulty, as related it may be the Motherboard, Remove the RAM, and see if anything is on screen? If yes, replace RAM, If still NO, then take any cards out, and check, if then OK, replace cards one by one until you get to the one that stops it, there is your problem, replace it. All we are trying to do is get anything on the screen, if we do, then you must redo the BIOS, as related before. Now if you get it going it still may not boot through to windows desktop, if this is the case, after you boot press F8 and select safe mode, when you get asked if you want safe mode or system restore, choose system restore and choose a date before you had a problem that should get you back. You just have to logically work through, until you find the faulty "bit" and replace it.
Posted on Feb 22, 2010
Testimonial: "Thanks for the confirmation!"
Emachine Wiring Diagram
What a Marvelous person!
You have described a 4-pin Peripheral power cable, ('P6'),
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
An IDE harddrive, of which the 4-pin Peripheral power cable example, is plugged into.
Another look at an IDE (PATA) harddrive,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136096
http://en.wikipedia.org/wiki/Parallel_ATA
However, I do not know if the flat IDE ribbon cable marked Slave, goes to a secondary Harddrive, or an optical drive. (CD/DVD drive)
Either way the point is moot. BOTH of those 'squarish flat black' units, HAVE a 4-pin Peripheral power cable to them.
Another hardware component, those type of power wires CAN go to, is a computer case fan.
However not ALL power cables have to be used. Sometimes there are extra ones. These are in case they are need later.
To summarize;
The optical drive, or drives; that you put a CD, or DVD disk in; can use a 4-pin Peripheral power cable.
(IDE/PATA optical drive)
Harddrive's can use a 4-pin Peripheral power cable.
(IDE/PATA harddrive)
A computer case fan may use a 4-pin Peripheral power cable.
Or the 4-pin Peripheral power cable you see, may simply be an extra one. One if needed in the future.
The eMachines T2245 uses a Trigem (Manufacturer), Imperial GLVE (Model name), motherboard,
http://www.ebay.com/itm/New-Emachines-Imperial-GL-VE-20021218-Motherboard-Socket-478-System-Board-/121098707716?pt=Motherboards&hash=item1c320ba304
Supports an IDE (PATA) harddrive, (Or 2 of them)
Supports an IDE (PATA) optical drive, (or two of them)
I DO hope you are following Anti-Static Procedures!
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static, BEFORE reaching inside your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface, of the metal frame of the open, empty computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Also I would like to add;
http://computer.howstuffworks.com/
http://www.hardwaresecrets.com/article/Anatomy-of-a-Hard-Disk-Drive/177
http://www.hardwaresecrets.com/article/Anatomy-of-an-Optical-Drive/179
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 24, 2013 | eMachines Emachine T2245 Power Supply...
Need manual for me-350v4
I NEED ONE AS WELL...This is the first computer item I have purchased without a manual. I can not even find a download for the manual. HELP!!!!!!!!!!!!!!!!!!!!!.
Feb 07, 2013 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
How do i put my hard drive inside? me
Open the external case, by removing some screws, and sliding the cover away from the insides.
Connect your disk-drive to the "power" and "data" connections, and secure the disk-drive with the mounting screws. Close the case.
Jul 25, 2011 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
How do I add more memory to my dell dimension 3000 computer thatn has a 34 GB Harddrive?
Go buy an IDE hard drive of whichever size you want, and connect it to the IDE cable that your current drive is connected to inside the computer. If you don't want to reinstall windows, you'll have to either purchase a separate IDE cable and connect the new drive to another IDE port on your motherboard (IDE cables are the thin, flattned cables that are fairly wide) If your current IDE cable has a freed up connection, ensure that your drives are jumpered properly with the master/slave options that should be printed on the drive itself, with a diagram. Your main drive (34GB) should be the master, the new one set to slave - this will keep the computer booting off of your current hard drive. It may seem intimidating, but installing a new hard drive is easy once you open up the computer and start comparing parts, looking for your hard drive ports and power supply cables. Just make sure the IDE cable and the power supply cable are firmly attached to the new hard drive when you install it.(power supply cable usually has a white tip, with four loosely bound wires leading to it) I hope this helps!
Nov 18, 2010 | Dell Dimension 3000 PC Desktop
This is different from original. ater installing,message says drive 1 not found
Newer SMPS comes with SATA power supplies.That is why insted of 4 IDE power connector, newer models comes with IDE 2 connector (Of course with same power rating i. e. same PCB & Components). And you have not connect power to one of your drive. Just purchase a IDE power cable splitter and connect power to all your drive and your problem would be solved.
Jan 27, 2010 | Dell (Y2103) 305-Watt Power Supply
I need a diagram of the atx pwr connector for an ASUS P4V8X-MX
If you mean power to the devices themselves, the 4-pin connectors coming from the power supply plug in to the drives. The red wire is +5 volts, the yellow wire is +12 volts and the black wires are ground (earthing) connections. IDE hard drives and CD drives use the same connector. SATA drives may have that same connector as well, but most use a different style. SATA-ready power supplies will have 1 or more plugs available. Adapters to switch from the 4-pin IDE plug to SATA type are available for supplies that don't have the right connector.
If you are asking what power pins from the mainboard power supply connector are supplying power to specific controller parts on the mainboard, that kind of detailed information is not available. Mainboards manufacturers do not supply circuit diagrams or repair information. They simply replace any boards that fail while still covered by the warranty, and expect you wil just buy a new one if the warranty has expired.
Much information about ATX boards including the power supply cable pins is found here:
http://en.wikipedia.org/wiki/ATX
Feb 09, 2009 | ASUS P4V8X-MX Motherboard
Sleep i think
SOunds like a possible over heat inside the case or the power supply is not stable. Try running it with the case partially open and seeing if there is any variation on  the board.
Sep 07, 2007 | BYTECC 1 Bay ME-350U2 USB 2.0 External...
Computers & Internet Logo
David Payne
David Payne
