Kenmore 80 20892990 stops before rinse full of water.
Stops before rinse full of water. After that it agitates once every approx. 20mins for 15-20 seconds on fast speed and stops again. If I cut power off for an hour or so and then manually switch it to rinse it may drain and finish the cycle or start drain and get stuck in the middle of it again.
  • Skumbrievich
    Skumbrievich Mar 30, 2014
    Checked the pump for a clog and it was fine. The problem persists.
SOURCE: I also need the answer...
where is the lint trap located
Posted on Apr 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore 110 Series 90 stops at the rinse cycle full of water
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. hence, the reason why you can get it to work sometimes by lifting and closing the lid. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
NOTE: For future reference, it is strongly recommended that you do not slam the washer lid or place heavy objects on the lid. This can cause damage to the lid switch.
Posted on Aug 19, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
jsrock516
  • 5911 Answers
SOURCE: my washer stops in the middle of the cycle, it
This problem is commonly attributed to a lid switch malfunction. I will need a more accurate model number to confirm (located under the washer lid along the tub rim). "110" is only the beginning prefix of the model number, which identifies the manufacturer. I will need the remaining numbers to determine how the washer is configured.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know. PS If the lid switch IS defective and you need instructions on how to by-pass it in order to drain the wash tub, let me know. In addition, if my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further.
Posted on Feb 26, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
