Question about GE (PSS26MSRSS) Side by Side Refrigerator
Where is the evaporator fan located in a ge gss22sgrf
    Habit-Forming:
  • 76 Answers
In front of the evaporator coil in the freezer compartment, behind the fan guard. you must remove the rear freezer panel to access it.
Posted on Apr 26, 2014
3 Suggested Answers
aasc
  • 1606 Answers
SOURCE: ge profile evaporation fan installation
It's located in the freezer compartment . May have to remove all panels , including the icemaker , to install it . If the fan isn't working though , the problem is probably the main control board , located behind an 8 " X 10" panel , on the back of the refrig . Usually , a resistor burns out and the freezer fan stops working .
Posted on Sep 20, 2009
tzweeb
  • 318 Answers
SOURCE: GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Posted on Jan 10, 2010
How do I access the evaporator fan in a GE apartment-size refrigerator model GTS12BBMARWW?
are u sure its where u say it is and not along the back side of the wall?
Feb 10, 2015 | GE Refrigerators
Refrigerator model ge GFSs6KKYSS refrigerator is not cold like it should be where is the evaporator fan located
This fan you seek is located above the evaporator. I would need a correct model number to give you more information as to its accurate location.
Aug 01, 2014 | Refrigerators
How to remove the evaporator fan gss22sgrf
HERE IS MY VIDEO. I REPLACED EVAPORATOR FAN MOTOR
Mar 30, 2014 | GE Hotpoint Top-Freezer Refrigerator
Intermittent tweeting sound on a profile gss22sgrf
There is more than one fan on your refrigerator I think you mean that the bearings and not the bushings are bad which could be true just have to figure out which fan it is.
Mar 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile evaporation fan installation. Where is it located?
Sep 19, 2009 | GE Refrigerators
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
