Question about Beko Dishwashers
On Off switch faulty
On / Off switch on Beko 1532 dishwasher won't stay down. Is this easy to replace myself if I buy a part? How do I get into the control panel? Many thanks!
  • Beko Master
  • 3,247 Answers
The switch is available from eSpares.
http://www.espares.co.uk/product/es1624719/onoff-switch?ModelId=1630729
The rear of the control panel will become accessible by removing the screws holding the stainless steel door panel from inside the door. Make sure the dishwasher is disconnected from the mains power supply.
Posted on Mar 30, 2014
Beko dw 450
It sounds like the arm may be damaged if it won't stay on. Get online and look a the diagram of your dishwasher. You can order the parts and they are easy to replace with just a screw driver. Arm and receiver unit needed.
Mar 05, 2014 | Dishwashers
Cannot programme to anything but a cold wash
The computer switch needs replacing (start control)
Jan 21, 2018 | Beko Dishwashers
Beko dsfn 1532 start button will not stay down
We have the same problem. How did you resolve this issue?
Dec 30, 2012 | Beko Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Beko dw 600 dishwasher, all programme lights stay on and it wont run or clear
I had this problem and followed the advice from Gallagher to no avail.
I sorted it as follows andd bear to mind I have never seen inside a dishwasher. I found the float valve and removed the connection to open circuit the switch, still the same, I then did the same to the sensor in the water container still the same. I concluded that the only thing left was the control module in the door.
I got the pcb on line for 22-00 and fitted it. job sorted
It says the changing of the module requires an expert, dont know why its a piece of cake.
Jul 08, 2012 | Beko Dishwashers
I have a slimline beko dishwasher. The control panel is stuck on a cold wash and we can't budge it. Model is dw450. Any ideas how to fix it or how to get at electrics to fix it?
The programmer is accessed by taking the front panel off, and loosening the door front. If it won't move either way it is faulty.
Apr 14, 2012 | Refrigerators
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
Beko dishwasher wont start it comes on wont fill up
hi there...have you checked the water supply to the dishwasher.......sounds either no water to the appliance or a faulty water inlet valve to the appliance
regards Sir Galahad
May 15, 2009 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
152 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
