Question about Electrolux ICON Designer E30SO75ESS Oven
How do i unlock the hindge when door is out
I have the door off and can not get it back on the oven
  • 20 Answers
This is quite tricky to explain, did you lock hinge before removal, if so then should be easy to put back in.
It is very difficult to unlock hinge once taken from oven and can potentially destroy door glass if you try!
You can try to unlock but will need some pump pliers, but best not to try unless experienced
How do take the door off of my oven for cleaning from Appliance...
Warmest regards
Richard The Repairman
Posted on Mar 31, 2014
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
We have a Westinghouse Polaris free standing oven and the door does not seal properly, huge waste of money heating the oven to have theheat escape! grrrrr ! can the door be adjusted to close properly?
this is usally one of two things the metal is stressed at the point where the hindges go into the stove remove door and flatten with a piece of wood and a hammer only if you can see the metal is bowed out,also the actual hindges may be worn and have exccessive play in them
Jul 16, 2012 | Westinghouse Ovens
Cannot unlock oven door
  • Here it is!
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    Jen-air electric oven jjw8530. Door will not shut all the way. Light stays on. Hindges have been replaced twice. Not hindges! Help!
    Bubbcrk,
    Is your door lock in the way? I think that your model has one correct? Have you checked the door light switch? If it is the switch that is keeping the door from shutting and turning the light out, you can get one fairly cheap.
    Please Clarify.
    Door Light Switch for your model
    http://www.pricedrightparts.com/products/Door-Light-Switch-PRP71002904.html
    Thanks Joe
    Jun 11, 2011 | Ovens
    Can not close the door
    how do you mean it won't close?it doesn't latch or are the hindges damaged and the door isn't closing tightly
    Apr 16, 2011 | Whirlpool RBS305PDS Electric Single Oven
    How do i put the oven door back on after i removed it to obtain measurements. now i can not get the door back on
    I had the same problem today I found that you have to extend the hindge enough to have the lock tabs lock into the door to hold the hindge in the extend mode. If the tabs are not back in the door it will continue to snap back. After you lay the door in place be sure to extend the lock tabs back up into the oven side towards the pins that you hindge lay on. WATCH YOUR FINGER TIPS!!!
    ken@mobilevapor.com
    Nov 14, 2010 | Ovens
    Can i adjust the hindges as my door does not seal closed i have a delonghi pro cooker ess903 thanks colin
    It is usual to be able to adjust oven door hinges.
    Normally the only solution is to replace the hinges.
    Hope this helps.
    Jan 12, 2010 | DeLonghi Ovens
    Jenn-aire JJW8530dds
    It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
    I would suggest you remove the oven door and re install.
    You do not remove any screws or anything like that to remove the oven doors.
    When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
    Aug 02, 2008 | Jenn-Air JJW8330D Electric Single Oven
    Adjusting the oven door hindges for a snug fit
    i wanna circuit board of inkjet printer and faluts finding
    Dec 19, 2007 | Frigidare FGB24S5DC Gas Single Oven
    Electrolux ICON  Designer E30SO75ESS Oven Logo
    145 people viewed this question
    Top Electrolux Ovens Experts
    ashburton
    Mack Baxter
    Are you an Electrolux Oven Expert? Answer questions, earn points and help others
