Question about Dell 5130cdn Color Laser Printer
I have no display on display and the motherboard is flashing green led 4 times.
No display at all on power up. motherboard has green led flashing a series of 4 blinks
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
  • 38 Answers
SOURCE: Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Posted on Oct 09, 2009
gewiz
  • 1263 Answers
SOURCE: Dell Inspiron 530. No power - replaced Power
hi,
Sadly that sounds like a dead motherboard.
Regards
Gewiz
Posted on Dec 05, 2009
Testimonial: "Very quick response, greatly appreciated. "
budmrtn
  • 11361 Answers
SOURCE: Dell E173FP power led orange/flashing failure returns
First, you can get the service manual here: http://elektrotanya.com/
If the transistors failed again, yes the 0.22uf (part of tuned circuits for the inverter transformer oscillator circuits) changed value, the frequency will be off and causes over heat on the transistors due to too much current draw, You can also have bad inverter transformer, you can check the DC Ohm value but if it has one short turn, it will not show up on DC Ohm test, you have to use ringer testing (I use SENCORE LC75).
http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 29, 2010
  • 3940 Answers
SOURCE: I have a broken Dell Precision 470 Workstation.
sounds like a motherboard failure.
Basic troubleshooting, disconnect all external connections except power, see if indications change, if no go remove all expansion cards see if any change, if no go disconnect all drives see if any change. If none, then motherboard.
If at any step you get a change in indications, then see if you can isolate the faulty item
DIAG LED info is here
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Posted on Jun 16, 2010
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
My power button come on and off and i make sounds 4 times my screen is not working too.
What is the color of the LED power light on the monitor? is it GREEN or AMBER(orange) - this is a display problem. The Display adapter(video card adapter) may be faulty or not installed(seated) properly on the motherboard. If the display adapter is built in the motherboard, you may consider resetting the BIOS by taking out the battery and putting it back on or use the CMOS reset jumber found on the motherboard.
Oct 28, 2010 | Computers & Internet
My Dell 8200 Desktop just stopped working. It turns on but doesn't boot; nothing appears on the screen. I was told this is the motherboard. Does that sound right?
two things
  1. What does the power LED on the tower indicate? Solid Amber? Flashing Amber? Solid Green?
  2. On the back of the Tower are 4 diagnostic LEDs, what do they indicate? Normally they flash thru several sequences and stop ABCD all Green. If the stop in another pattern, post the pattern.
Feb 13, 2010 | Computers & Internet
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
No video flashing, green power led
power red flash and not operating system
Aug 26, 2009 | Computers & Internet
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have a hp pavillion f1723 but it wont switch on, the green led power light keeps flashing, what does this mean?
count the times the green led flashes? and how it flashes that´s an error code for your problem. it can be the motherboard or power.
Aug 13, 2008 | HP Computers & Internet
Changed ink jets alarm flashing number 5800 showing
Hello Saron Girl,
its not 5800 its 5B00
7 times LED Blink Waste ink absorber full [5B00] - Ink absorber (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864 / 4221 / 4257)
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
4 times LED Green Waste ink counter resetting
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
the printer returns to the menu selection mode automatically.)
Regards,
May 14, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
lights in green to indicate that a function is
selectable.)
resume/Cancel button. (DO NOT release the Power
button.)
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Dell 5130cdn Color Laser Printer Logo
145 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
