Question about Golds Gym Cycle Trainer 290 C Exercise Bike
There is too much resistance on the Cycle Trainer 290C. it was working just fine then one day it just got hard to peddle and you can hear its tight. how do i fix that?
Ni-Trac VA-500 exercise bike ( which I bought 2nd hand, in good condition) resistance has stopped working
If it was clicking the resistance motor is stuffed replace it they are quite cheap and easy done, but also make sure the flywheel is tight as they loosen over time as well. You'll need the crank tool, I made one from a m20 metric fine thread and drilled and tapped but you could probably get one from a local cycle shop. Easy job, worth doing these bikes are real nice ??
Jan 30, 2015 | Exercise & Fitness
I have a Gold's Gym trainer 410 treadmill. I
please RUN the software calibration for easy diagnostic and fix it.
Go under the HOOD cover for motor, and see the instruction and follow the instruction
God bless you
Jul 20, 2013 | Exercise & Fitness
Reebok rx2.0 console stopped working
Hi I'm having same prob. Did you ever get solution
Feb 25, 2013 | Reebok Indoor Trainer RX 2.0 Upright Bike...
How do i bleed the brakes on my 1984 ford mustang never done it before
same as any nother car. take off mastercylinder cap. get a helper set in the drivers seat. apply pressure to the brake peddle. with a box or tube wrench break the fluid *** on the top of the calliper/back of drum loose. foot pressure on peddle should push it to the floor -hold it on the floor! tighten the *** on the caliper/drum tight-ish. not over tight. then let peddle up off floor. pump till you get resistance/tighteness. hold pressure on peddle, loosen *** again and peddle will go to floor again tighten ***, lift up peddle pump for pressure. repeat untill all air is out of line/ or fluid runs out clear. never let the master cylinder get low on fluid. have plenty on hand. repeat for all 4 tires.
Aug 10, 2012 | 1984 Ford Mustang
ProForm 675 elliptical is very hard to peddle
use the next steps:
Step 1
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed switch. These elements will be roughly the same size, and the reed switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed switch using your screwdriver. Move the reed switch by hand until it sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the display and heart rate monitor are working properly. If not, move the reed switch slightly so it is closer or farther from the magnet, then try the machine again. Once you've found the correct location for the switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
8_1_2012_1_02_58_pm.gifGod bless you
Jul 31, 2012 | Exercise & Fitness
Summit trainer peddles squeak
1) Try to LUBE according with the maintenance instruction manual, and tight any bolts+nuts loose, and replace any parts worn.
1a) Go to the troubleshooting
2) If you do not have download for free> www.fitness.manualsonline.com
or www.iconservice.com or www. retrevo.com
God bless you
Jun 10, 2012 | Life Fitness Integrity Seires Summit...
Squeaking peddles
1) Lube inmediately, and tight the bolts+nuts, and replace any parts worn.
2) Follow the instruction manual according the schedule maintenance
God bless you
Jun 10, 2012 | Life Fitness 95Li Summit Trainer Build Up...
My Kinetic trainer increases resistance when I increase speed. How can I maximize resistance at low cadence of say 60 rpm?
You can't with this type of trainer. You have to have a trainer where you can manually adjust the resistance. The closest you can do is shift your gearing.
Apr 04, 2011 | NRS Kinetic Road Machine Trainer
Golds Gym Cycle Trainer 290 C Exercise Bike Logo
Top Golds Gym Exercise & Fitness Experts
Steven's...
Steven's...
Sock Puppet
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
