Question about Philips"fr 975"receiver"digital Audio/video Surround"digital Cinema & Link"w/
I think my receiver may have a blown fuse, when plugged in and I try to turn it on the red power light comes on and immediately shuts off, could this be a fuse problem?? If so how can i fix this
Trying to fix my receiver, I dont know if I have a blown fuse or what.
    Master:
  • 435 Answers
If your main power fuse was blown, there would be no power at all. You may be looking at a blown preamp or an overheated component inside your receiver. You may want to take it in to a service technician. Have you tried to contact Philips customer service?
Posted on Mar 30, 2014
What would cause new fuse to blow when powering on (Sony STR-DN1030 Receiver).
Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Sony STR-DN1030 7.2-Ch. Wi-Fi Network A/V...
The receiver turns off 2 seconds after turning power on....red light blinks
have you got all the wires wired in correctly.have you extended your speaker cables and not insulated them(wires could be touching each other).maybe a blown fuse inside.although i think if it were a fuse,it probably wouldnt light up at all.my experience with my system is that if i wire up something wrong,the power button light which is a green light,will change to red to let me know something is not right.(its warning me before i blow something up)!!yours might be doing the same thing only flickering to let you know somethings wrong.If none of this helps then you should send it in for repair.Dont be afraid to open your system and look for a glass fuse(s) about 20mm long.if you find one and its blown,then you are lucky.a blown fuse is better than a blown system
Oct 16, 2010 | Denon AVR-689 Receiver
Nintendo ds lite won't turn on
http://www.wiredextreme.com/count.php?refer=2119 this site actually fixes them for you
Jul 01, 2010 | Nintendo Video Game Consoles & Games
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
Onkyo TX8211
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Aug 12, 2009 | Onkyo TX-8211 Receiver
Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Apr 27, 2008 | Audio Players & Recorders
Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Mar 27, 2008 | Denon DRA-395 Receiver
Onkyo SR502 Shuts off by itself
It is not a blown fuse. Your baby is in its ***** throes! It is fubar. You have either a damaged power supply or blown output stages (since sounds horrible it is probably this).
Sep 17, 2017 | Onkyo TX-SR502 Receiver
So how do you replace a fuse?
Hmm. Tricky problem. It could be the main fuse blown and the standby power suply is only working. Worts case senerio is that one of your amp is faulty and the unit is in protection mode. If the fuse is dead then you are lucky, just get the cover open, remove the power before hand, and do a little search, Most of the time it will be in a glass tube ( glass cartridge type) rated at 250VAC with a nominal of around 5 to 7 amps rated current. U can check it with DMM in a continuity mode. If fuce blown replace with the same rating and it has to be slow blow type. Cheers
Sep 11, 2007 | Onkyo TX-SR500 Receiver
Philips"fr 975"receiver"digital Audio/video Surround"digital Cinema & Link"w/ Logo
289 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
