Question about PowerBolt Sport & Outdoor - Others
Replace rebounder net
Need to purchase replacement PowerBolt rebounder net
    Master:
  • 435 Answers
Did you think about going back to where you got the first one and inquiring about a replacement net?
Posted on Mar 30, 2014
Change batteries in weiser Powerbolt elec deadbolt
Pull the inside cover away from the door, to remove. This exposes the battery holder. Replace all four AA batteries with new alkaline AAs The cover snaps on. Align top first.
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Mar 31, 2014 | Weiser Lock POWERBOLT ELEC DEADBOLT
I guess I need to purchase a new cap that goes over the pins. Mine is missing and my door unlocks when the lock button is pushed,
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Sep 05, 2012 | Weiser Lock Powerbolt 1000 Lock
Powerbolt keeps beeping after battery install
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Navigate to the complete page that I cut this from by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Then go to: US & International/FAQ Categories/Keyless Entry/Powerbolt 1000/Search Results/ How do I troubleshoot my Powerbolt 1000?
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Be prepared to find the replacement costs to be expensive enough to warrant considering a new lock altogether. Personally, I've seen enough problems with the Powerbolt on this website to make me consider buying almost anything but! I think that Schlage makes a pretty good product.
Jul 29, 2012 | Weiser Lock Powerbolt 1000 Lock
Our Powerbolt 1000 started beeping this morning. I've tried replacing the batteries and disconnecting the power strip. The beeping continues. I am unable to reset the code. Are there any other...
Powerbolt is Beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
Take out batteries and unplug power strip.
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
Since you've already gone through the battery change, etc.,this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Also, they will be able to get the correct part on order for you.
Jul 16, 2011 | Weiser Lock Powerbolt 1000 Lock
Does the green light flash all the time on my powerbolt and when I open the door from the outside there is a beeping sound this has never happened before not untill I changed the batterys.
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, they will be able to get the correct part on order for you.
Jul 03, 2011 | Weiser Lock Powerbolt 1000 Lock
How reset my powerbolt because i put in the firs step the batteries and the machine dont work what need to do?
Follow this link for battery replacement and programming:
May 07, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Hi i have a triumph thunderbird 1996 900cc. when i travel over dips in the road the rebound on the front folks tops out creating a load knock. How do i adjust rebound on the front forks? I have turned...
fork oil replacement and seals fixed mine when it did that. Like you, I also tried to adjust the settings to no avail, then replaced oil to proper level for both sides, and presto, fixed.
Dec 07, 2010 | 1995 Triumph Triumph Thunderbird
Need replacement elastic bands for mattel rebound game, yellow in colour?
you can always just use the elastic bands u get on broccoli that seemed to work real good for me as a kid or nd strong thick elastic band.
Jun 07, 2010 | Crosley Rebound Game and Board
When i enter the combination you can hear the mechanism turn, but the deadbolt is not moving. is this powerbolt shot, and do i just need to replace it? i expect the gears are not meshing?
If this is an electronic lock, you may need to replace the batteries or check that the power supply is not frazzed if it is connected to the mains.
If it's mechanical, a couple of good squirts of lubricant might get it moving.
Other than that, you might need to call a locksmith.
Regards
Jan 14, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Powerbolt 1000 uses up batteries in a week
Get in touch with Weiser Canada via the contact info on their web site (http://www.weiserlock.ca/wei-eng/contact.htm) for a replacement under warranty (the Powerbolt has a lifetime mechanical guarantee). i have two rental properties with Powerbolt locks on them and have found - over the past 3 years - that it's safest to just replace the batteries on a 4 month schedule to ensure the tenants don't get locked out! The batteries actually last for longer than ~ 6 months, but i prefer to be on the safe side ...
Cheers,
Jun 08, 2009 | Weiser Lock Powerbolt 1000 Lock
Sport & Outdoor - Others Logo
181 people viewed this question
Top PowerBolt Sport & Outdoor - Others Experts
Are you a PowerBolt Sport and Outdoor - Other Expert? Answer questions, earn points and help others
