Kenmore washer 80 series
Hi the water will not stop it just keeps going no matter what cycle it is in. Is something froze it another problem, I fixed the switch and that seems ok
    Problem Solver:
  • 9 Answers
Hello the waster level in most washing machines is regulated from a pressure switch air activated.. From the bottom of the appliance there is a pipe that connects to a switch, it is either... Blocked, came off, or there could be a hole in the system letting air in.. It is very rare for the switch to fail but this is also possible as well as a faulty control module depending on which type of branded washing machine... Hope this helps...
Posted on Mar 30, 2014
Testimonial: "Great advise, thank you! :-):-):-):-)"
  • steve dref
    steve dref Mar 30, 2014
    yes that is it! !!! it was blocked, with ice, the water froze in the pipe. used a hair dryer and it is working, thank you :-):-):-)
    Master:
  • 435 Answers
How old is this washer? Is it digital, or does it have the handle you turn to choose what kind of load you want? Which switch did you already fix?
Testimonial: "Not sure of age maybe 10 years old, I replaced the lid switch and it has a dial to turn for cycles"
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series washer
The switch you're talking about is called a "lid switch". It can be by-passed, but it is there for a reason. The switch is used to prevent the tub from spinning or agitating with the lid open. This is a safety measure to prevent personal injury. You mentioned that the switch was "missing". It may have simply come loose and fallen inside the washer between the case and tub. More than likely, it is hanging by a ground wire and a plug. If you can retrieve the switch and screw it back in place on the rim of the wash tub opening, you may actually fix your problem. However, if the switch is broken, you need to replace it. Here's how:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
PS To answer your initial question about by-passing the switch, when you remove the console and disconnect the lid switch, you can take the connector that is MOUNTED ON THE WASHER TOP and remove it by pressing the release tabs and pulling it from under the tub rim. This is the connector plug that runs to the lid switch. Cut the plug from the switch, leaving a couple of inches of wire. Short the two black wires together, insulate the ends and cut the green wire flush. You now have made a by-pass plug. Simply plug it in to the connector that is RUNNING FROM THE TIMER and (voila!), you have a working washer. Keep in mind that now your washer will NOT stop when you open the lid. Use caution if you're going to operate your machine in this manner.
Now...if you're going to go this far, you should replace the switch. A new switch runs about $35 or less. Its an easy repair if you follow the directions. Keep the plug handy in the event that you run into this problem again and need to drain and spin the water out.
Good luck to you and let me know if you need any further assistance.
Posted on Feb 22, 2008
SOURCE: I also need the answer...
where is the lint trap located
Posted on Apr 07, 2008
  • 1028 Answers
SOURCE: Kenmore Washer Model #110.25862400
ck lid switch
Posted on Aug 29, 2008
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Posted on Jan 05, 2009
SOURCE: kenmore 80 series washer leaves soap residue on clothes no matter
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
Posted on Mar 19, 2009
Whirlpool thin twin lt7100xvn0 wont complete the fill cycle
sounds like a bad water pressure switch not to difficult to do and not to costly. if its defective it will continue to fill and overflow never going into wash cycle. ( u can check it by having it set to wash and removing the long clear plastic tube hose from the tub not the switch, and blow into it, or u can use another small tube and insert it into the pressure switch & blow into it. if it starts the wash cycle the diaphram in the switch is ok if it doesnt the switch is bad) and u may want to check ur inlet water valve as u may have a bad water inlet valve. which can also keep water flowing no matter what u do even when unplugged from wall. Have u ever noticed water in the tub for no reason like the next day? these can be checked with a multimeter.
Jan 15, 2015 | Whirlpool Washing Machines
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 80 series washing machine - won't stop filling with water on rinse cycle - never moves to next cycle - if I stop machine and manually move to spin, the machine does spin and the water drains
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Jan 16, 2010 | Kenmore 24032\24036 Top Load Washer
Du1100xtpq7 dish washer keep repeating wash cycle doesn't go past this just keeps washing
Hi
Thanks for using FixYa. If the cycle doesn't complete, check these:
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 07, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
80 Series Kenmore Washer, No draining or spin cycle
It does sound like a controller problem. Go to: SearsPartsDirect.com for parts diagrams and part numbers.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Water will not stop
Hi, If you can stop the water from filling by shutting off the timer, you will need to look into the water level switch as the roblem. If the only way you can get the water to stop is to shut the supply valve off, you will need to change the inlet valve.
To check this water level switch, remove the 2 screws in the front or rear corners of the controlpanel and let it rest on the hinges. No locate the level switch. It has 3 wires and a 5/16" hose attached to it. Remove the hose and blow down through it. If it seems to let air through, replace the switch. If there seems to be some resistance in the hose, follow it down beside the tub and pull it off the cup fitting. Now use a thin wire (coat hanger might work) and see if there is something blocking the hole in the cup. Once it gets cleared out, hook the hose back up and try the wash cycle.
Please let me know if this has helped or if I can assist you further in tis matter.
Thanks
Vic
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
