Question about Garden
Water getting in oil - Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Hi if the water is getting into the oil of the water pump there is an oil seal between behind each piston ( usually three ) thet will need to be replaced. drain oil tank . remove head you will see seals that need replacing ( plastic ring oil ring and oil seal) 1 of each per cylinder. caution to keep all the parts ( under the bigger bolts are non retun valves , they should not need to be replaced. sometimes replaceing the pump head is cheaper.
Posted on Mar 30, 2014
Engine mixing water and oil in the sump. took the cylinder head and engine block for pressure test. but still mixing what could be wrong. The above was returned as not cracked.
hi there.
Water in the engine - Water can get into your oil sump in two ways: ... Water in the oil- Coolant leak due to non-watertight seal (cylinder head gasket, etc.). If this happens, there is a leak and water is getting into the oil.
Water in engine oil
If you found water in oil car , this water engine car section is for you!
Water in car engine? Water should never be allowed to get into the oil in your engine or gearbox. Otherwise, it will result in significant foaming, dramatically reducing the product's lubrication properties.
  • Water in car - Water condensation in cold air or combustion gases: this phenomenon is extremely rare and only occurs at specific temperatures.
  • Water in the oil - Coolant leak due to non-watertight seal (cylinder head gasket, etc.). If this happens, there is a leak and water is getting into the oil.
Water in motor oil can cause serious damage to your engine - the oil will be denatured and no longer effectively cooled.
Contact your repair centre as soon as possible.
Dec 01, 2017 | Cars & Trucks
Getting oil in the water
if you are getting oil in the water but no water in the oil the cooler inside the radiator is leaking. If the oil has redish to brown color it is the trans oil cooler leaking
Mar 27, 2014 | 1997 Dodge Ram 1500 Club Cab
Water get into oil
Water in oil makes the oil go grey / milky or white . Check the cooling system by a pressure test and if it is holding then it will not be water in the oil.. If you are referring to transmission oil then the tan colour indicates burnt oil, and must be replaced. Water in that oil will also be a white cherry/ milky colour.
Mar 18, 2014 | 1993 Buick LeSabre
My 97 Neon has white oily substance in radiator
Hi it sounds your head gasket need's replaced ,,,As for the water creamy white that means that oil is getting in to your water .
The head gasket has gone water can get into oil
but it also oil can get into water can also
water can be lost down the exhaust.
Replace head gasket clean out radiator
Jul 30, 2013 | 1997 Dodge Neon
Refrase 1996 hyundai excel ,oil in water no water in sump oil.
Oil in the water is usually a sign of a head gasket leak, because the high pressure oil passes through to the head in order to lubricate the camshaft.
The oil return passages also go through the head gasket, but are too low pressure to usually cause any problem.
As long as there is no water in the oil or loss of water, I would keep driving it.
The oil in the water will not hurt anything. If it eventually gets worse and leaks water, then you will have to do the head gasket. Costs about $500.
Of you can do it yourself for about $75 if you know how to use a torque wrench.
Jul 03, 2012 | Cars & Trucks
Water getting into oil
If its just condensation in the oil cap or dipstick, to some degree its normal. However if you have water in the oil and its very creamy in texture, its probably a head gasket leak, or cracked head. Its important to get it repaired soon, or total engine bearing failure will result.
Jan 29, 2011 | 2001 Daewoo Leganza
I have filled the water reservoir several times a week. There is no leaks what could be wrong and where could the water be going?
Check the oil fill cap to see if there is any water or antifreeze leaking into the oil through a bad gasket in the engine. To much water getting into the oil will ultimately cause your engine to seize, ruining your engine. A light tan substance on the underside of the oil fill cap also is indicative of water getting into your oil.
Oct 26, 2010 | 2000 Volkswagen Beetle
Milky oil on my wr450f 2004
your water pump seal and oil seal have failed on the water pump shaft. Replace both seals noting which way the seals face. replace the water pump shaft if it is scored. Chaz- Moto DC
Jan 20, 2010 | 2004 Yamaha WR 450 F
Perkins 7.5 gen. I am getting oil in the water ,
your water jacket in the block has a pin hole in the block and the pressure of the oil versus the water is higher and forcing oil into the water you need to put dye into the oil and water and trace the leak,then "magnaflux" the block and repair it
Nov 14, 2009 | Electrical Supplies
1999 tahoe 5.7L has a problem. Water mixed with engine oil.
If it was not overheated real bad the intake gaskets are a big problem on those engines
Nov 04, 2009 | Chevrolet Tahoe Cars & Trucks
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
