Question about Dryers
My fan belt broke I'm trying to put a new one in but dont now hiw it go's on cause it broke off I just nedd a pic of it
  • 44 Answers
There should be a diagram or picture of the configuration on the fan belt shroud or on the hood. Just look up when the hood is open.....
Posted on Mar 31, 2014
5 Suggested Answers
Mike258
  • 1498 Answers
SOURCE: Replacing fan belt
Hi Don,
It's easy and you won't need a prybar.
  • Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
  • For putting the belt on: Get the belt around all the pulleys except the A/C compressor or Alternator.
  • The tensioner pulley is on a spring loaded arm. Get your socket on the center nut of this pulley.
  • Slowly pull the ratchet toward the center of the engine. The pulley will pivot on the arm allowing you to get the belt on the final pulley.
  • Slowly release the tension.
  • You're done
Hope this helps you out.
Mike
Posted on Jan 15, 2009
leedavidian
  • 1420 Answers
SOURCE: Fan belt broke, replaced, good for 5 months, then came off
what kind of vehicle do you have engine size?
Posted on Dec 24, 2009
  • 2002 Answers
SOURCE: have a rebuilt 6.2 chev
It sounds like the alternator is not properly lined up. You had the belt on right the first time. Put it back on and before you start the truck check the alignment on the belt. From the side of the truck look down thw belt to the fan pulley and see if you notice a slight bend, or use a straight edge to do the same thing. Also sight down the belt to the crank for the same thing. Yoiu may have to shim out the alternator brackets to get the belt in line with the other pulleys. Hope this helps.
Posted on Oct 17, 2010
Testimonial: "you were right. got it aligned thank you"
heatman101
  • 43501 Answers
SOURCE: MY BELT BROKE AND I
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Sep 17, 2011
I put in a new timing belt but when i start engine there is no sprocket do you know what causes it?
have the OBD codes read you may have left a lead off somewhere the code reader should point you in the right direction , dont want to alarm you but if the timing belt breaks whilst engine running it will almost certainly cause some sort of damage so might not be as simple as no spark
Apr 29, 2014 | 2004 Mitsubishi Galant
Starting problem
You did not give the make model and year, so I will give a generic reply. You could have an accessory that locked up and broke the belt. Try taking the belt back off and see if the engine will crank.
May 11, 2013 | Cars & Trucks
My serpentine belt broke drove car 30 miles home without belt, got a new belt put it on cranked car up took for test drive got back opened hood realised the exhaust manifold was red hot. Turned A/c off...
  • Well, that belt drives everything including the water pump. When the belt broke and you drove it no coolant circulated and the exhaust glowed from overheating. A red glowing manifold usually only happens from excessive heat caused from modified engines. But in this case this is almost surely what happened. You are lucky you did not blow your engine. Park it and let it cool down for a few hours.
Regards, Tony
May 25, 2011 | Mercury Sable Cars & Trucks
Have a rebuilt 6.2 chev diesel. broke alternator belt. got new belt and put it on lower pulley, fan pulley and alternator. it keeps throwing the belt when revving the engine up. tried ac pulley, fan pulley...
Oct 17, 2010 | 1988 Chevrolet G30
Drive belt broke, identify wich one and can I repair myself ?
The one that is still on is most likely the AC. The other belt are for the water pump and alternator or power steering pump. (the starter has no belts). Yes get a new belt and put it on like you said. Loosen whole alternator and slide back and forth to put on belt.
Jan 10, 2010 | 1994 Toyota Corolla
We need to replace a fan belt that broke. Does
You can do it. If it takes longer than 10 minutes something is wrong. If its a V8 make sure the tensioner is good, Fan belts rarely just "break" so check all the pulleys.
Dec 16, 2009 | 1995 Jeep Grand Cherokee
How do i fit a fan belt on a audi a4 1.9tdi
im trying to upload a pic of the belt routing it wont let me email me i can send it to you jr-motors@blueyonder.co.uk
regards John
May 15, 2009 | 1996 Audi A4
Dryers Logo
15 people viewed this question
Top Dryers Experts
