All of a sudden my vizio smart tv will not shut off had to unplug and remote is not working
Will not shut off unless unplug and remote is not working
    Genius:
  • 1,039 Answers
Replace keypad and main board if needed.
Posted on May 13, 2014
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
  • 13 Answers
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Posted on Jan 22, 2010
Can I fix my vizio e472vle? Or do I need to purchase a new tv? Any Idea what i would need to repair the problems listed below (flciker of menu and smart functions).
Follow these steps to reset your TV:
  1. Unplug power to your router.
  2. Perform a Clear Memory or Reset to Default on the TV.
A. Using the VIZIO remote, press the Menu button.
B. Use the Arrow buttons on the remote to highlight System and press OK.
C. Highlight Reset & Admin and press OK.
D. Highlight Reset TV to Factory Defaults and press OK.
E. If you have not manually reset the parental code, please input 0 0 0 0 when it asks for the password.
F. Highlight Reset and press OK.
G. Wait for the TV to turn off.
The TV will turn back on and the Setup App process will begin.
  1. Plug power back to router.
  2. Perform the setup process and reconnect to your network.
Jun 02, 2017 | Vizio Televison & Video
How can i install facebook app on my vizio smart tv after its been deleted
Go to the App store and search for it, and then download it again. The is a video tutorial in the main link.
Method 3 Vizio Smart TVs
  1. Verify that your Vizio Smart TV is connected to the Internet using a wireless or wired connection. ...
  2. Power on your television and press the "V" button on your remote. ...
  3. Use the arrow keys on your remote to highlight either the Yahoo TV Store or CTV Store. ...
  4. Press "OK" to launch the app store.
More items...
4 Ways to Add Apps to a Smart TV - wikiHow
www.wikihow.com/Add-Apps-to-a-Smart-TV
facebook app on my vizio smart tv Google Search
Jan 04, 2017 | Vizio Televison & Video
Add dvd to vizio smart tv
chechk ou ece or cec settings
Dec 28, 2016 | Vizio Televison & Video
My vizio tv won't shut off and it will not work on any of the smart functions? I unplugged and left overnight and it did not help it. It is only 3 years old.
The board where the power button is located is probably bad. The power button itself will be part of that board, which will also have the other controllers (i.e. "all on one board"), which would explain your multiple problems.
Mar 08, 2016 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Have 2008 vizio smart tv-how do you program a new remote to the tv or tv to the remote?
Hello Mat,
Read the instruction manual that came with the remote as that has codes in it and the procedure to program the remote also. You can also look up the codes via the internet using the make and model of the remote. The listing will usually have all possible codes that might work with your Vizio tv, and you have to try them all until you find the 1 that works.
Good Luck!
Rich Lilja
Mar 26, 2015 | Vizio Televison & Video
Remote control not working
vizio remotes are junk. I have 70 inch led smart tv and both remotes are junk. I have no idea what brand is better to replace it with.,
Sep 19, 2014 | Vizio M422I-B1 42IN LED LCD Smart TV Full...
Need Motorola cable box DCT2224 code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 12, 2014 | Vizio M-Series Razor M471i-A2 47" LED...
Smart remote
It is not the Remote. The problem is in the receiver section of the TV.
Feb 26, 2014 | Vizio Televison & Video
My Vizio SV472XVT 47" HDTV
Unplug the TV from the wall. There must be something wrong with your circuit board. Call customer service for what to do to fix your TV or get a new one.
Mar 05, 2011 | Vizio SV472XVT 47 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
