Ps3 error 8002f821
Can start ps3
My ps3 controller wont connect. i hit the ps button and all 4 lights on controller start blinking. ps3 is hoked to tv with a hdmi cord and it says no signal.
Hey there,
You just need to sync your controller with your ps3. To do so, use the USB cable that plugs into the controller and into a usb port of your ps3.
You will then be able to start your ps3 and push that ps3 button on your controller, once the ps3 has started, and you'll be good to go.
Jul 13, 2011 | Sony Playstation 3 (PS3) Console
My PS3 turns on without a problem. Thing is, it will either freeze while the pre-game credits are rolling, while I'm playing the game, or it will simply display an error message when I try to start the...
Instead of starting the game. Try to update the PS3 software.
The link below will show you how to do so.
http://us.playstation.com/support/systemupdates/ps3/ps3_update_system/index.htm
Aug 17, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 will start to make noise when i play?
well the noise is a loose nut or could just be the fans,and/or reading cds........but if it won't read some ps3 games......well idk
Apr 17, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 wo't start up. I turn it on wavy sony ps3
Your hard drive is bad. you need to replace it.
Sep 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not start up. no display
sounds like the resolution is not set correctly on your tv or your ps3 settings. make sure they both are set to 720i to start, if you have a HDMI cable, that should be the min resolution your tv will do.
Find out the max resolution your tv can do, and set the ps3 to output that.
720i is a good place to start.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 start screen will not show up on my TV
I had this problem before. I messed with the settings on my PS3 and My TV until the settings matched. My PS3 would show the home until I loaded a game. I turned off then on my PS3 to get to the settings. My TV manual had the types of videos it supported so I went with the second to highest setting it supported and it worked. Hope this helps.
May 29, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 wont start
There is nothing wrong with the PS3. I read in the users manual that when the the green light on the PS3 turns yellow or flashes yellow the PS3 is too hot and you need to turn it off. It has never happened to me because I keep my PS3 in a open area.
When the PS3 gets to hot you need to let it sit and cool for a little while and then you can turn it back on and start playing again. If the PS3 cools for a while and it still doesn't work you need to call Sony.
Jul 07, 2008 | Sony Video Game Consoles & Games
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
