Question about Saws
Sip 240 v two lives and two neautrals into motor, how do i live wire to test motor?
Sip 01314 model.
    Sergeant:
  • 272 Answers
There should be a wiring diagram on the motor -- Maybe under the cover plate where the wire goes into the motor -- Maybe on the plate on the side of the motor.
The wires are two hots (red and black), one neutral (white) and one ground (green or bare). The red and black need to come from the two terminals on a 220/230 volt breaker.
Posted on Apr 18, 2014
I have a LG washing machine,model WD1256RD that won't power up I've changed the main power board no joy.
did u check for a fuse as some of the newer models have a fuse sometimes located along the body or tub ? it may have bad fuse, also check for live voltage where the power plug wire attached to the motor . Your schematic should show which wire from the motor is the live wire. There 2 wires u can jumper with a test plug with 2 stripped back wires and a prong at the other end, when plugged in and attached to ur motor it should start, if it starts then ur power cord is bad. This is a live power test with a multimeter to check for proper voltage. as you may not be getting voltage to the unit
Nov 25, 2016 | LG Washing Machines
Whirlpool Dryer IED4400SQ0 wont heat
Check your thermal fuse and the thermal cut-out fuse, two different fuses that can cause a dryer to run and not heat when open, or some dryers will not start when one of these has gotten too hot and opened....Usually caused by venting restriction of too much lint, common problem...........
A open operating thermostat or the high limit being open are also possible........;.
The other checks are live voltage checks, timer contacts, wiring, temp and internal motor switch......schematic is probably in back of control panel........
Takes some reading of a wiring diagram, understanding how to split the circuit ............Not for beginners.............Hope this helps...........do not forget to unplug dryer when doing anything on unit besides live voltage checks on circuits,,,,,,,,,,,,,,,
Mar 12, 2014 | Whirlpool Inglis IP8200 Dryer
Ground leakage detected device cut the power
Take wires out of plug and the wire from the connecter box of machine. With multi tester test earth to live and earth to neutral. If there is a short circuit it will show on which wire it is. Next disconnect live and neutral wires from motor and run test on all wires. If no short the motor is faulty and test the motor connectors. If the short is not found the motor is not the problem but the control system. Disconnect all wires from controls and test everything isolated and individually.
Apr 16, 2013 | Washing Machines
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
I purchased a Honeywell HT-380BP Turbo fan disassembled and in a box at a thrift store. Is there anything by way of a circuit diagram I can reference to put it back together? There's a motor with seven...
I Guess nobody has the Answer....
Red= high
Yellow= med
Brown= low
White=com
Gray= neautral
Black 2X= live? ACL on the board.
the cap is connected to white & gray.... I want to bypass the electronic board w/ a manual 3speed switch cause I think the motor is still good!!
nobody has the answer?
Aug 27, 2010 | Honeywell Dryers
I have a next door neighbour with an outside powered sun blind / awning, he has not been able to get to work. The 240v tubular motor (Lid technology) has a five wire flexible cable colour codede as folows:...
first there is no 240 volts mostly you mean 220, and why 220 well it must be a heavy awning, green is always ground, then wires colored black and brown are power to motor, never heard of using blue wiring as a neutral wire, best bet is to call the manufacture and ask how it should be wired, if all else fails call an electrician
Jun 25, 2010 | Home
How do you test the voltage for a dryer? Bought a testing meter to test the continuity of (250 or 120...) just don't know how to go about it.
You cannot test continuity with this unless you have a death wish. You could see if you had power going to an object but that would not let ye know if power was going through it. Both sides of the heating element could be hot and therefore light up the tester but that would not PROVE the heater was ok. To do that you would need to remove a wire (while live) connect up to the live 240 volt wire and the leg to the heater THEN if the light comes on yeah you have continuity but you could be KILLed in the process. It would be better to get a meter and check each item for continuity:
Oct 06, 2009 | Dryers
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Saws Logo
96 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
