Fuego e3 error
It's repeating frequently, when it's starting it's ok then after few minutes I got that E3, then it stop and after that start again and again it's stop, and again and again............
  • 1,249 Answers
This problem is due to abnormal high temperature in the "hot" coil. It usually happens because of a few things:
1. Dirty filter(indoors)
2. clogged coil(outdoors)
3. bad blower fan or other air restriction
Posted on Mar 30, 2014
bobotfel
  • 236 Answers
SOURCE: Fault E3
Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Posted on Dec 30, 2007
SOURCE: Carrier Thermostat Displays Error Code E3
Carrier Air Conditioning display an error code E5 and then swtich off
Posted on Aug 09, 2009
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
SOURCE: I have a Goldstar GP120CE Portable with an error
If you have a goldstar GP120CE portable air conditioner with the E3 error and it's not under warranty you may be out of luck.When I called LG, (who owns Goldstar), they said these units are not cost effective to repair so finding a company to service them is difficult. If it were under warranty they would exchange it..
Posted on Jul 19, 2010
SOURCE: i keep getting error code
PORTABLE AIR CONDITION ERROR 3E
Posted on Aug 05, 2010
Error code E3 on Samsung DMS500TRW dishwasher
3E error in Samsung dishwashers normally relates to high temperature error. This means the dishwasher is detecting over 80deg C water temperature. However if it is 5E that means drain error. If your dishwasher is draining correctly then please check the error again.
Apr 14, 2014 | Dishwashers
Classic Flame 39EB500GRS Error Message E3?
I had same problem. Just stopped worked and blinked E3. I used the troubleshooting wizard on ClassicFlame's website. Shut power off (it's hardwired to 220v) for a couple minutes and it started back up. Never did find out what caused the error.
Dec 10, 2013 | Classic Flame 39EB500GRS 39 inch Builders...
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Its flashing E3 and chiming. and stopped washing
Hi
E3 is an overload error and indicates that the washer motor is not running properly. You can take out some clothes and then restart the cycle by pressing the START/PAUSE button. After this, if the error appears again then check the motor connections, if everything appears fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag MAH6700AWW Neptune Front-Load...
E3 code error.
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Sep 20, 2009 | Maytag MAH2400A Front Load Washer
E3 showing on Kenwood model KDW243A
E3 means longer heating time. Usually this indicates the heater element has failed.
Aug 01, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I have E3 error code on a Bosch washing machine maxx classic - what does it mean? thx!
"E3" on a Bosch Maxx means the door is not closed properly. Either there something preventing it from closing properly (blockage) or there is a fault with the locking mechanism.
Jun 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Stops pumping in middle of program
I know it is a bit late, but maybe it would help the others.
This E3 error means, that the water temperature did not reach desired level (for example 60C if you are using 60C program) in a given time.
The dishwasher starts the heater and waits for example 10 minutes for the water to reach the temp.
The heater is located on the left side of the dishwasher - it heats
water flowing from the bottom bowl to the sprinkler on the top.
There can be few reasons:
- the heating device is dead - easy to check - if the water is hot when E3 appears, then this is not the case
- the water duct from the bottom bowl to the top sprinkler is messy, and needs cleaning (there are some rubber pipes of quite small diameter)
- the temperature sensor (thermistor) is dead / not responding fast enough. It is mounted to the bottom bowl and can be reached from the front cover, under the doors.
Hope it would help to somebody.
I have already had this and few other problems. All of them have about 5-6 reasons to appear, and I think I know all of them for now :-)
For me, knowing what to expect and how to fix each E-something, this dishwasher is perfect and will last forever :-)
Regards,
Piotr
Jan 19, 2009 | Candy Dishwashers
Not starting, giving a H:E3 in the window
Let your breadman cool off competely. I put mine outside for ten minutes and it worked again. (H:e3)
Oct 25, 2007 | Breadman TR444 Bread Maker
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
