Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
Power out Failure alarm
A two year old Pentair Intelliflo pump has a power out failure alarm on the control panel. I checked and the voltage to pump is 245v. The green power light is on and the alarm light does a constant flash. Every few seconds I hear a clicking sound. Any help or ideas of what to check next would be appreciated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Need more info will pump motor spin freely if not turn by hand remove cover on back of motor sometimes they lock up with power off turn by hand a few times then try with power
Posted on Apr 05, 2014
adamh294
  • 310 Answers
SOURCE: We lost our password for
On the normal vs-3050, you need to reset the whole unit. You do this by holding all 4 speed buttons for 30 seconds. After thi, shut off the power at the breaker. let sit for 2 minutes. Restore power and all setting are reset. I cant find any information about the SVRS model, but it should work the same way.
Posted on Oct 28, 2010
SOURCE: Pump works in spa mode, but doesn't work in pool mode. Why?
We need more info. Which control system is it? Suntouch, easytouch, intellitouch.......? It sounds like a programming problem in the controller.
Posted on Jun 26, 2009
thepool
  • 78 Answers
SOURCE: pentair intelliflo variable speed pumps
Extensive information available is available from Pentair. Owners manual http://www.pentairpool.com/pdfs/IntelliFlo4x160and4x100OM.pdf Quick start guide http://www.pentairpool.com/pdfs/intelliflovsQSG.pdf
Posted on Apr 21, 2010
adamh294
  • 310 Answers
SOURCE: I have a pentair intelliflo
Check the wiring connections, and count how many times the alarm light blinks upon start up. It is probably a loose or broken connection, but the alarm blinks will give us more information to go on if its not.
I install these regularly for 3 years and the only time I saw this incident was when I had a bad connection inside the J-box.
Posted on Jan 11, 2011
john224
  • 1378 Answers
SOURCE: pentair pump won't start, doesn't
Thank you for posting your question here on Fixya.com.
Use a meter to measure voltage at the motor terminals...If the unit is getting power the trouble lies within the motor; if not look at the controls. The click should be the relay for the motor closing. If you do not have power to the motor you will want to start with that relay; check for incoming and outgoing voltage. I imagine that if there is no power to the motor you will find the relay is bad. The click suggests the low voltage side is working and the relay is trying to close but if the primary is burned up no power will get to the motor.
If the motor is getting power you'll probably want to pull it and take it to a local electric motor repair shop. They should be able to identify what failed and offer a repair quote if the motor can be salvaged.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
Posted on Mar 22, 2011
Have a ow fault on my pentair intelliflo vf pump What does this mean? How do I clear fault?
Here is the manual: http://www.pentairpool.com/pdfs/IntelliFlo%20VS+SVRS.pdf
Don't see OW however OV typically means over voltage. Cycle power or hold RESET on the keypad
Sep 07, 2015 | Pentair Pool & Spa
Overcurrent alarm intelliflo veriable spee
check incomming voltage was pump wired correctly see diagram on side of motor
Jul 12, 2014 | Pentair IntelliFlo VS-3050 & VS+SVRS...
How do I manually reset my Intelliflo pump? The priming alarm came on after I tried to vacuum pool. Now it wont work.
turn off breaker to pump for a few minutes, then back on this will reset your alarm. If the problem returns ,check other posted solutions. In a few weeks i may have location of someone who repairs circuitboards for pentair pumps, as i am having one repaired now due to lightning hit.
Jul 22, 2012 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I have a pentair intelliflo 4 x 160. It was running, I turned it off to clean my DE filter, I tryed to start it right after I put the filter back to gether, it turned just a second then the alarm light...
Jan 11, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
1,315 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
