Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
Inglis refrigerator, model No. 1JT198300
Vent in refrigerator under the freezer is producing water, is something plugged?
  • 4 Answers
No, This is normal. As the freezer gets cold it also dehumidifies the air in the freezer. There is a drain tube in the bottom of the freezer that directs the water into the basin, where it will evaporate. You should wash the basin every six months and add a little bleach (1/4 cup) when you reinstall the tray. This keeps it disinfected and odorless.
Posted on May 30, 2014
We bought used fridge Inglis/Niagara Model ICT85000 Mfg06/93 when we close fridge door freezer door opens. When we close freeze door fridge door opens. This is a top freezer. Is there a repair
Inglis are a budget make. The cold for the fridge comes from a vent from the freezer. Don't let the door slam. You must close them gently.
Dec 30, 2016 | Refrigerators
Got water dripping into fridge from "vent" from
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Refrigerator leaking water from freezer compartment, freezing along walls of freezer, but running water out under door
Sounds like the defrost water drain is plugged up. It could be a piece of food wrapper fell into it, or something. What make and model is it? Top freezer? Side by Side?
Dec 30, 2009 | Refrigerators
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
What causes water to run in bottom of refrigarator
This is caused by plugged drain tube. When the freezer goes through a defrost cycle the water drains down a tube in the back of the freezer to the pan under the refrigerator. When this tube is plugged the water doesnt drain through the tube but drains through the vent in the refer. The easy way to fix this is to unplug the refrigerator for 24 hours.
Jun 30, 2009 | GE Refrigerators
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Refrigerators Logo
65 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
jeff5may32
John Tripp
John Tripp
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
