Question about Vivitar ViviCam 5399 Digital Camera
Vivicam 5344 battery cover stuck how does it open?
How does the battery cover open?
I have a vivitar vivicam 46 and I can't open it to put the batteries. How do I do it?
Slide the face cover to the right away from power button. It will open right up.
Jun 28, 2012 | Vivitar Cameras
Is there an automatic lens cover?
Hi, yes there is one and you may just be able to see the diagonal line in this picture. It is the division between the two parts of the automatic lens cover, which should close to protect the lens when the camera is turned off.
If you cannot see a cover then it may be stuck open, perhaps by dust, but the camera should otherwise still be able to work normally. You probably cannot get to the cover to manipulate it with a pin and perhaps blow on it with a lens puffer, but anyway this might cause some damage.
In use the cover might come free again and I hope these comments are helpful.
Dec 26, 2010 | Vivitar ViviCam 5385 Digital Camera
How to open a vivicam to replace the batteries?
Put your thumb on the battery door and slide it down a bit until it pops open.
Aug 22, 2010 | Vivitar ViviCam X327 Digital Camera
Lens cover does not open and camera shuts off it is a vivi 5385 vivitar digital
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
Jun 09, 2010 | Vivitar ViviCam 5385 Digital Camera
Replaced battery, radio asking for code? Where or
Try these:
4316
1156
5624
3241
2151
2145
5241
4524
4513
3451
3346
5436
4362
6361
1165
5843
2152
2512
2453
3451
4316
2253
3241
4353
2152
5613
1651
1554
4136
1325
3116
5324
5344
1636
1341
3265
4345
5513
5613
3265
3251
6645
5256
4513
6654
3644
2136
1641
1634
1326
2621
3413
3462
2346
2235
5632
4325
Jan 15, 2010 | 2004 Suzuki Verona
Battery is jammed inside ViviCam 8300s digital camera
I had to bore into the battery case and muscle it out with a knife. The battery had cracked and swelled inside the camera, so that's why it wouldn't come out.
New battery is in, and the camera works better than ever!
Jan 20, 2009 | Vivitar ViviCam 8300s Digital Camera
ViviCam 2.1 Mega Pixel Digital Camera...broken battery door
just get the battery cover fix by taking your camera down to a camera shop like jessops. there is no need to get a new camera.
Nov 25, 2007 | Vivitar ViviCam 4345 Digital Camera
Automatic lens cover is stuck
The lens mechanism is damaged.The only known solution is to get a replacement lens unit and replace it
Aug 08, 2007 | Vivitar Vivicam 5388 Digital Camera
Vivitar ViviCam 5399 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
SHARCNET-USA
SHARCNET-USA
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
