Question about Maytag MFX2570AEM French Door Refrigerator in Stainless Steel with
Water draining into freezer Maytag MFX2570AEM
We find water on the floor once a week. Seems to drip from a grill in back of the freezer. Pools in the bottom of the freezer, drips out front when bottom fills. I was told this might be a clogged drain line from the defrost, especially as it goes days without leaking, then only leaks a given amount. Is this repairable by home handyman?
  • 16 Answers
Certainly should be, if it is a blocked drain tube and not a broken fan or defrost unit.
Assuming this appliance to be a frost free unit, generally (as I don't know this particular unit), there should be an outside access panel on lower rear of unit. Behind this, you should see the compressor (large round or square sealed container) and a drain tube leading to it or to a receptacle on it, which allows the defrost water to drain from the freezer compartment, and evaporate using the heat of the compressor. It will be this drain tube that may be block with food debris or even (as I found on mine) a plug of mould. My tube just pulled off and I was able to completely clean through with fresh water. Inside the freezer, there must be a drain channel leading to the drain tube outside. This may be visible or hidden behind panelling and, If the outside drain tube was blocked, will probably be full of iced up defrost water and will need to be cleared, either by leaving unit switched of or, by careful use of a hair dryer - GENTLY - so as not to warp the plastic insides. Once this is cleared, ice can then melt off the hidden freezer grills when on defrost cycle and escape correctly to the outside for evaporation.
Posted on Mar 31, 2014
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
heatman101
  • 43501 Answers
SOURCE: water is dripping out the
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 22, 2011
Testimonial: "Thank you for your help..I will try the defrost tip to see if there is ice blocking the drain, as the unit is cooling properly."
Maytag model MF12569VEQ1
Dick,
Odds are your drain line is clogged. Often it is ice that is the clog. Here is what ya do: Empty the Freezer and unplug the refrigerator. Get a hair dryer and after removing the ice on the floor of the freezer and drying the bottom of freezer prop the hair dryer up inside a glass or ceramic (insulating) casserole dish pointed at the back bottom of freezer. Put hair dryer on hi and close the door. After about an hour (as you check in on it every ten min\'s) look for water dripping from the drain line into pan. If need be, use a shop vac to blow in from the top and draw (suck) on the drain tube at bottom. I bet this fixes it. Plug frig back in and observe over next week or so.
Oct 12, 2013 | Maytag Refrigerators
I have a GE refrigerator which leaks water. Point of origin of the leak is unknown but the water drips down the interior and pools at the bottem until it overflows and drips on the floor from the fro
You have a frozen drain in the freezer side of frig....take back panel off in freezer and you'll see your build up of ice take out ice and pour hot hot water down drain....make sure clear and clean then you're done....easy peasy....
Oct 02, 2012 | GE Refrigerators
Water is leaking from the bottom corner of the freezer
Is it an excessive leak ie pools of water on the floor? If it is not a major leak it might be normal condesation being drained.
Aug 28, 2012 | Cars & Trucks
Water leaking
the bottom tray/salad compartment will always get a fair amount of condensation because they are glossy plastic(bathroom paint is matt)the only "cure" is kitchen towel under the tray and remove once a week.as for the drain it is normally at the back and does collect a fair amount of "moss"in the tube,pour some clorine bleach down to clear any out.the design of the shelves directs the side/back condensation down the drain.
Apr 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
The unit is dripping water from the opening in the ceiling of refridgerator
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Whirlpool Refrigerators
Water dripping in to freezer bottom ten pools on
Sounds like you have a drain that is plugged. When it goes into defrost the water hass no place to run. Thats when you get water like that. I would defrost it completly. Then try to get to the drain and pour hot water slowly to see if it goes all the way down to the pan. If not. Yu may have to have air pressure to go thru the drain.
Aug 30, 2009 | Refrigerators
Water builds up in the bottom of freezer
had this happen once and my drain was clogged. in the freezer section you have to remove the rear panel. 2 1/4 screw bolts. after exposing the coils the drain hole is in the middle. i clesred the hole with my wet/dry vacuum. first sucked then blew air through it. hasn't done it again and its been 1 year so far
Apr 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag MFX2570AEM French Door Refrigerator in Stainless Steel with Logo
487 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
