Question about Vacuums
Strange noises hi team, I recently changed the starter in my car... after which, I had a number of problems occurring... firstly, two fuses keep blowing, causing the speedometer and the gages in the dash to go black, no indicators could work.. I had over heating problems, once the gages stopped working, and the transmission started to slip when I was driving... now I am hearing a noise like air escaping from somewhere in the engine... what can cause this noise? How worried should I be?
    Master:
  • 347 Answers
It really helps if we had the year make and model of the vehicle to further help you.
Posted on Jun 07, 2017
b0sslady2001
  • 357 Answers
SOURCE: Kirby G5 - Stopped
The carbon brushes in the motor need to be replaced. Very IMPORTANT....... DO NOT run the Kirby anymore until you get this fixed. If you do, the armature will be in danger of being damaged. (and that part is expensive!) The carbon brushes are reasonably priced, and you can use this online guide to get to them and change them. It's a guide for replacing the power switch, but it will help you change the carbon brushes too. Hope I've helped...
Marci
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Posted on Nov 09, 2007
SOURCE: belt slipping
Get some belt dressing from an autoparts store. With gloves on and the belt cover off spray on the corner of a rag (or equivelant)and carefully turn the vacuume on for 3-4 seconds while holding sprayed area of rag on the drive surface of the belt avoiding getting your fingers or the rag caught in the drive rollers. Repeat for best results. This may help clean burnt rubber off belt and give fresh surface for better belt/motor pinion/brush reaquaintment. Did this to our Bissel Velocity Widepath. Had same problem. Great performance after belt dressing was applied. If that sounds too dangerous for ya, get a new belt and pretreat it prior to install. Be shure to remove burnt rubber from brush.
Happy Vacuumin'
Posted on Jun 30, 2008
Samyfam
  • 379 Answers
SOURCE: dyson dc14 died, no power after burning smrll
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Nov 07, 2009
Testimonial: "thanks so much for taking the time to reply...sounds like we need a replacement!!!...will get the dyson ball this time..hope it's good! thanks again!"
  • 175 Answers
SOURCE: my dyson has stopped working. There was a burning
The Motor sounds like it has gone bad. Bagless machines like these always have motor problem. If it is under warranty then it will need to be shipped to Buffalo New York. I would trade in in on a Riccar vacuum. You can get 20 years out of those for less money.
Posted on Nov 30, 2009
SOURCE: roomba stutters on one wheel causing it to quit
Try setting the Roomba on the floor, powering it up, pressing down hard on the front, just above the front wheel, and hitting "clean" or "spot." My Roomba had the same problem, and this seems to do the trick for it. I think it has something to do with the Roomba thinking the front wheel is extended (which would indicate a cliff) even though it's really not.
If this doesn't work, you might try pressing down over whichever wheel doesn't turn when you turn the Roomba on.
Posted on Apr 21, 2010
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
Why does my Dyson animal squeal on carpet
Hi, there are a number of different Dyson vacuums and they vary widely in construction. Unfortunately most models have an "animal" version so that's not helpful in identifying your particular cleaner. If you know the actual model number, I'm sure I might have some ideas of what will cause squeeling.
Off the top of my head, DC25's often have issues with "whistling HEPAs" but not usually carpet related, DC17's may exhibited brush roller noises if the belt is damaged. DC07's, 14's, 33's all have a clutch drive which sometimes fail causing "racheting" or other strange noises.
Feb 16, 2012 | Vacuums
Mine is the polti vaporetto leco aspira. 4 years old. while using the vacuum only, it had a strange noise for a few days then the unit started smoking and died. can i change a part or is there a fuse that...
the vacuum motor might be overheated hence smoked and burned the winding, dissamble it it you can try to replace fuse with the same rating only. if there's no fuse then motor winding already burned.
Feb 02, 2011 | Polti AS700 Canister Steam Vacuum
WHEN I TURN OFF DYSON DC25 ANIMAL..GET A LOUD NOISE AS THE MOTOR IS SHUTTING DOWN....
I am experiencing the same problem with dyson 25 when the motor is shutting down - i hear a strange noise ....
Jan 05, 2011 | Vacuums
My dyson dc14 wont turn on at all
Hi I would suggest you first check the Fuse in the plug. This is quite common.
If after chnaging the fuse the machine still doesnt work then please come back to us. Let us know that you have checked the fuse andthe machine still wont switch on.
Im confident it will only be the fuse. Unless you have had strange noises or funny smells coming from the machine.
Oct 26, 2010 | Dyson DC14 All Floors Upright Vacuum...
Dyson will not switch on
Usual problem is the fuse in the plug. Check the fuse first. If this fails then your problem is either the Switch (Unlikley) or the Motor. Its unlikely the motor would break without warning though. If you have had any burning smells or funny noises recently then its the Motor.
If there are no Smells then im confident its only a case of changing the fuse. Quite common for the fuse to go.
Oct 23, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
Strange noise
Strange question...
Sorry, but you need to describe the problem in a way that others will understand. "Strange noise" tells us nothing of any use; you need to describe the noise and also mention what you've checked so far on your DC07.
Aug 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Stopped working
Hi!  Sorry you've had to wait so long for a reply, but I've only just stumbled upon your problem.  You probably don't need help any longer, but here goes anyway! You will not find a fuse, because there isn't one.  If your Henry just stopped, without making any strange noises or smells, it's very unlikely that you have a motor problem.  Quite often the wires can become broken inside the electric cable - with no visible external damage - especially where it enters the plug and can be subject to both bending and pulling stresses.  If the machine came to me for attention, that's where I'd look first.  Check the wires for electrical continuity. If you still need help, and this solution doesn't work, please write again and I'll suggest some less likely things to look for. Good luck!
Jan 25, 2009 | Numatic Henry Bagged Canister Vacuum
Electrolux aptitude upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=113651&thid=541998
Posted by inoubliable on Apr 24, 2008
My Electrolux is about 3 years old. Never had any problems with it until recently, it is LOUD. It doesn't seem to make a 'normal' running noise unless it butts up against a wall, furniture, etc. trying to vacuum is like being on a jet runway. Is something clogged? Does it just have issues from not being used for about a year? (Last house had no carpet).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds to me that you have a broken fan, in every vacuum I have seen with the loud noise such as you described, it has been a broken fan or fan blade and is in need of replacement. You can try to do it yourself but I suggest going to your local vacuum cleaner dealer for service with the problem. Remember, a suggested belt change if the belt is flat would be 4 to 6 months and If you have a geared belt the belt change would be one year or better depending on wear factor. So, if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Electrolux EL5010A Bagged Upright Vacuum
Fuse blows after about 50-60 seconds
Hi.
If the motor is not smelling of burning or making strange noises I would think you have a problem with mains lead having an internal short circuit. Replacing mains lead should sort this.
If motor is smelling or not sounding correct then you need a new motor.
http://dysonmanuals.inc.io/
Oct 26, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
