Question about 473P 3-Button TX Remote
How to disable my alarm for a 476P 3 button keyless entry
How do you turn off an alarm for a 2005 Saturn Ion
Disarming an Armed System/Silencing an Alarm
If system arming has been requested by the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system in arm pending mode, SECURITY indicator flashing and doors open, perform 1 of the following:
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
Jun 24, 2016 | 2005 Saturn ION
How to disconnect the alarm
Depending if it is a aftermarket or a factory alarm, they should all have fuses that can be removed. By removing the fuse, you may lose your keyless entry option. Most aftermarket alarms have a siren that is usually mounted under the hood in the engine compartment area. I've seen where people have cut the wire going to the siren to disable it but keep the power going to the alarm system to keep the keyless entry still functional if it came with the alarm system.
Factory alarms usually use the existing horn for the alarm. If that is the case, you might need someone who is experienced to disable the circuit so that the horn will not sound if alarm goes off but the horn will still be functional when needed. Hope this helps.
Dec 20, 2014 | Cars & Trucks
How do I disable the security alarm on my 1999 Subaru Legacy? I do not have a keyless entry
If your just dealing with the alarm/horn going off all the time, you can try disarming it when it goes off by putting the key in the ignition and turning it on and of three times ending with the last turn in the on position. This will stop the alarm from sounding.
Jul 29, 2014 | 1999 Subaru Legacy
How to take automate car alarm off silent mode
{: ) When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter • After a battery reconnect, if the battery was disconnected with the CTD system armed
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position. • To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event): - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and switch to the ON position Locking the Vehicle Without Arming the CTD System Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Apr 23, 2011 | 2007 Chevrolet Tahoe
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
My car will not start and engine not turning over. Alarm keeps going off.
I would imagine that you should start by reading the manual. If the alarm is going off, most likely that has disabled the engine from starting. Find what triggered the alarm, turn it off and the engine will start again. I have seen this happen when the doors are locked with a keyless remote, then entry is gained using a key and not hitting the horn button on the keyless.
Apr 22, 2010 | 2000 Suzuki Vitara
Had car starter installed now the passlock light stays on. He took the key out while the vehicle was running. They disconnected the battery and hooked back up but that did not work.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the Content Theft Deterrent (CTD) armed mode. Also, disconnecting the battery or pulling fuses does not disable the armed mode, since the body control module (BCM) stores the CTD mode status in memory.
• To disarm the CTD System in arm pending mode, SECURITY indicator flashing and doors open, perform one of the following: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle. • To disarm the CTD System in the armed mode: - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle. • To disarm the CTD System when activated, alarming mode. - Press the UNLOCK button on the keyless entry transmitter. - Insert a valid key into the ignition and start the vehicle.
Nov 04, 2009 | 2005 Chevrolet Equinox
Did the 96 toyota camry come with an alarm if so how do I disable
actually your car has to have keyless entry, it's part of the alarm system that is given you problems. I had a similar issue with my 87 camery, sounds like they still haven't fixed it in 96.. anyway the fix was for me to take the VIN number over to my local dealer dish out about 35 bucks and get the remote control unit for the alarm system. That also gives you keyless entry :).. So for 35 bucks it was well worth the investment.
In order to disable the alarm there should be a red or black button under the streering colum to left side. You must put the ignition in the run position, and then hold this button for thirty seconds it should disable the alrm until you repeat that procedure.
Dec 30, 2008 | 1994 Toyota Camry
Auto door locks
To activate the autolock feature, use the following steps:
  1. Enter the five-digit permanent entry code into keyless entry keypad (14A626) .
  1. Press and hold the 7/8 button on the keyless entry keypad within five seconds of entering the code.
  1. Press and then release the 3/4 button within five seconds of pressing and holding the 7/8 button.
  1. Release the 7/8 button on keyless entry keypad within five seconds of releasing the 3/4 button. To deactivate the autolock, repeat the above sequence.
Dec 17, 2008 | 1995 Mercury Cougar
473P 3-Button TX Remote Logo
32 people viewed this question
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
