Question about TVonics DTRZ250
Requires a pin number
My Hard drive is full and I need a pin number to access but I don't have none. Spoke to my original supplier and they told me 0000 which didn't work they then said that they couldn't help me anymore
Why is this Win7 Ultimate x86 PC showing an error 80-pin Connector not found and boots only into win7 RE recovery mode?
The PATA interface was originally designed as a 40-pin system and still is. The ribbon cables were originally 40-wire cables. A special type of cable with 80 wires was then created to improve data throughput rates. Note that the number of pins remains 40, with a special type of ribbon connector connecting ground to 40 wires internally. The ground connections are placed between each of the data carriers to reduce cross-talk and allow up to 3 times faster operation. ATA33 is supported by 40-wire connection, ATA66 & ATA100 require 80-wire. Motherboards can check the speed of the data throughput to determine if a 80-pin cable is being used. Some BIOS setup options allow for this feature to be turned off. The HDD or DVD must support ATA66 or higher to work at the higher speed of a 80-wire cable.If you connect a slow hard disk or DVD drive on the same ribbon as a fast hard disk then the system will default to the slower speed. You also need to make sure the master and slave are connected to the correct connectors on the cable.
Firstly try each drive separately to see if the 80-pin error goes away.
Rather than master/slave on one cable, try each hard drive as a master on separate cables (IDE1 & IDE2).
Secondly, the boot partition may have corrupt data preventing boot. You should check both hard drives for errors by connecting to another PC if possible. This would also allow you to back up any important files so that you can re-install the operating system if required.
Jun 01, 2016 | Computers & Internet
When I rang the product suppliers they told me that they take the postage fee and wait 14 days for me to approve or send back. Non approval means they take the full retail cost from your account, obvi
Depending on your form of payment, contact your bank or credit card issuer. There is no requirement to accept or return unordered merchandise. Once you have notified the supplier, any new shipments are unordered. Dispute the charges and ask for a refund through your bank, credit card, Pay Pal or other fiduciary.
Jan 09, 2015 | Computers & Internet
Having problems with my ink cartridges, now I've used compatible cartridges as advised.
You may have gotten a cartridge that was in the store for a long time. Some cartridges may get solidified ink in the nozzles. Try a new cartridge from another dealer.
Oct 04, 2014 | Epson Artisan 710 AllInOne InkJet Printer
How to reset bios password in lifebook ah531/gfo series
you need to force a bios clear. often you need to get the system to default into a bios setup to do this, if you have more than one memory stick installed try removing one an boot up. this should generate a bios error due to the memory size mismatch. If it doesn't, power back down, reinstall the simm and boot back up and see if this error will bring up a bios error and allow you into setup. If neither of these work, try removing the hard drive and power up. If none of these work, Fujitsu (the original mfg) played an obnoxious game and used an external software access bios config, and this will require an original disc to access.
Sep 05, 2014 | Fujitsu LifeBook Computers & Internet
I am unable to access the phone because its pin is locked and I don't remember the code how can I hard reset the phone from the pin menu
take this and rate me.
Look for small pin hole in the set inset a non conductive pin like a plastic spoke into it.
Sep 10, 2010 | Palm Pixi Cell Phone
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
How do I program a new Keyless entry remote to my 2001 Jeep Grand Cherokee Laredo?
Programing Sentry keys: 1. Dealer-Programming additional Sentry Keys (requires ONE original key)
In situations where only one key is available, keys must be programmed by the dealer via the Secured Access Method. The Secured Access method applies to all vehicles. This method requires the use of a DRBIIIt scan tool and will also require that you have access to the unique four-digit PIN code that was assigned to the original SKIM. The PIN code must be used to enter the Secured Access Mode in the SKIM. This PIN number may be obtained from the vehicle owner, from the original vehicle invoice, or from the DaimlerChrysler Customer Center. Refer to the appropriate diagnostic information for the proper Secured Access method programming procedures.
2. Self-Programming additional Sentry Keys (requires TWO original keys)
"A" through "G" below is a quick summary of the steps that are required for programming. Following this list, "1" through "6" takes you through the same process in greater detail.
Quick Steps:
A. Purchase a blank key and have it cut
B. Insert original key #1 into ignition and turn to On
C. Wait 5 seconds and turn key to off
D. Immediately insert original key # 2 into ignition and turn to on
E. Wait 10 seconds for SKIS indicator in dash starts to flash
F. Turn ignition off, insert new blank key and turn ignition back on
G. Once SKIS light stops flashing and turns off, your new key is programmed
You can find more details in Sentry Key® Immobilizer System (SKIS)
Hope helped with this information (remember rated this help) Good luck.
Nov 09, 2009 | 2001 Jeep Grand Cherokee
LAPTOP- WHEN YOU TURN IT ON IT WONT OPEN TO THE START PAGE
This is generally the indication that the hard drive has failed and needs replaced. Replace the hard drive, format it, and install a new operating system and you'll be set.
Jul 25, 2008 | Acer Aspire 5100 Notebook
Having problems with my acer travelmate 4060
Get virus scanner/remover, and then try restore to a date when the computer was in full working order. If that does not work, try to backup valuable data files before original default factory settings, and get model-specific drivers etc from Acer and Microsoft websites.
May 25, 2008 | Acer TravelMate 2300 Notebook
Harddrive self test
i cannot find anything on this, it may be a fault code because the self test didnt report back correctly, if you are able to boot into windows, right click on your c drive, properties and click tools, then run a check to see if there are any bad sectors or system files.
Sep 06, 2007 | HP Compaq Presario V2555US Notebook
TVonics DTRZ250 Logo
48 people viewed this question
Top TVonics Televison & Video Experts
 Mikey
Mikey
Are you a TVonics Televison and Video Expert? Answer questions, earn points and help others
