Question about Radio Communications
On a 2007 freightliner Columbia which side is the cb and which side is the stereo
    Novelist:
  • 500 Answers
Most newer trucks have a matching box that both are connected too.
they connect the stereo and the cb together on the anntennas.
Posted on Apr 01, 2014
2 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: weather Radio won't work on 29 Nightwatch
Hello papapyr07,
It looks like you are trying to run the CB and the commercial radio off of the same antenna at the same time? This I gather is failing. This may be due to the pre-wired antenna having a filter on it to prevent exactly what you are trying to do. If this is the case you may have no choice but to run a separate antenna for your CB (this is the most logical choice), now you can try to find the filter if it is an external filter and remove it and use an antenna matching network to connect the CB to the existing antenna system (next logical, but may void the antenna system warranty). In any event you will either have to run another antenna for the CB or find and remove the present antenna filter.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
My freightliner 2007 columbia overhead light won't turn on when door closed , can anyone help me...
Either the bulb is burned out or the switch is not feeding power to the overhead fixture.
Oct 28, 2015 | Cars & Trucks
Code icu 140 columbia detroid engine
I googled: icu 140 columbia detroit engine
There are a number of answers. They should help.
May 07, 2015 | Freightliner Columbia Dash Panel: 2002...
Abs light is on all the time sometimes I get a code
Abs sensor will need replacing, cleaning them won't help, you need a code reader to see which one needs replacing then you need the code reader to delete the fault code
Feb 11, 2015 | Freightliner Columbia & Century Class 120...
Replacing expansion valve
following the line connected from the front mounted condenser to the compressor pump at front of engine , it's mounted in that line ,(small) use extreeme caution as theres a lot of pressure there on that line , fyi if your expansion valve is plugged your compressor is bad as well!!
Aug 31, 2014 | Freightliner Columbia & Century Class 120...
Can not figure out where fuse is for the heater motor and the bright light on 2002 freightliner columbia
Columbia has a fuse panel on passenger side dash board,and I believe the other one is drivers side panel just beside your seat it has one flat screw too turn and unlock it.
Feb 17, 2014 | Cars & Trucks
Want to install an apline stereo into a freightliner columbia
Just follow the Aftermarket Wiring Diagram and you will be fine
Apr 12, 2013 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
06 freightliner columbia sm codes on 12 speed smart shift
2005 freightliner columbia smart shirt does not take a gear and code shoes up sm.
Apr 24, 2012 | 2007 Ford F-650
Radio Communications Logo
106 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
