Question about Kenmore Refrigerators
Noisy compressor is there a fix for a noisy compressor besides replacement?
    Top Expert:
  • Kenmore Master
  • 10,875 Answers
No get a new one
Posted on Mar 26, 2015
Noisy AC compressor Jaguar X type 2.0D
Isn't there an old trick where soap on the belt can quiet things down ?
That might help you decide whether the belt needs replacement.
Sep 29, 2012 | 2003 Jaguar X-Type
Noisy air conditioning pump
Hi guys,
I have a 2.0 diesel X type and when the AC is switched on and the centre of the pulley on the compressor goes around it sounds like there is a very noisy rattle from the engine. It is OK when AC is not on. any ideas, and can this be fixed without replacing the compressor.
Oct 17, 2011 | 2004 Jaguar X-Type
I have a compressor 5 tons, when I checked the said compressor I found out that the internal parts were noisy. Please advise what would be the possible cause of that internal parts noisiness of the...
Contaminated oil causing internal parts to wear against each other, broken motor mount inside compressor (if Hermatic), bent rod or crank. Something that will not be an easy fix, sorry. I would use it till you lose it.
Mar 11, 2011 | Heating & Cooling
What does compressor getting noisy on ocaisson mean? Do I need to assume failure is immenient or could it last a while longer?
It is hard to say how long any appliance will last, but I would not replace solely for a noisy compressor. Most all compressors with age will get noisy on start up and shut down. If there is an espically loud knock on shut of check the mount bushings or for broken/lose mounting hardware
Sep 17, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
I also had a noisy compressor
Your compressor draws a lot of power even when operating correctly. When failed, you can expect that fuse will blow with all that extra resistance inside.
Jul 29, 2009 | 2002 Oldsmobile Bravada
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Noisy compressor
Compressors are availbe, sorry most compressors are sealed and can be replaced only
Apr 30, 2009 | Heating & Cooling
Bad ac compressor
U should replace the receiver drier, also called the accumulator, replace the high side line fixed orifice as well, you will need to drain the old compressor and measure the oil as well and add 6 ounce's to that amount you measured from the old ac compressor. and of course you will need approx four 14 ounce cans of R134
Apr 25, 2009 | 2000 Ford Taurus
Ac clutch going out on 93 dodge dakota
If the clutch is noisy from a bad bearing then don't drive far,if the compressor clutch pulley bearing seizes up it will freeze the pulley and the belt will burn off, and you are stuck, if you mean the anything else besides this drive it.
Dec 08, 2008 | Mercedes-Benz 400-Class Cars & Trucks
Air condition problem
When you say "noisy", is it a metallic grinding noise? Or, did someone overcharge the system. If the compressor IS internally noisy, replacing it is only half of the job. Anytime that comperssors fail, metallic particles get in the system, from the grinding of the compressor vanes or bearings...and need to be removed. Most of the time, they are trapped in a device called the "receiver-dryer", located next to the condenser in the front of the car. So, replace the compressor, replace the receiver-dryer, and evacuate the system. Hold a vacuum for 30 minutes, and then recharge. Not replacing the receiver dryer will damage the new compressor.
Sep 09, 2008 | 1994 Toyota Camry
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
