Question about Soundstream RUB1.2500D 2500 Watts RMS Mono Block Rubicon Series Subwoofer Amplifier
Why would my 2500 soundstream Rub1 amp keep going into protection mode
The amp cutting off and hear a clicking noise
    New Friend:
    Problem Solver:
  • 6 Answers
Take a look inside it could possibly be a/some capacitor/s. If it is replace more than just one because they can also be going bad. This is a cheap fix they cost less than one or two dollars a piece.(if this is the problem)
Posted on Mar 31, 2014
2 Suggested Answers
SOURCE: amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Posted on Jan 02, 2008
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
Amp 1000sx
it sounds like protection mode is on check to make sure no wires are touching metal or the frame
Aug 19, 2013 | Soundstream Car Audio & Video
I have 2 Soundstream SPL 10 Car Speaker
need to know model number on amp, and the impedance of the woofers
Apr 06, 2012 | Soundstream SPL 10 Car Speaker
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
Transmission protection mode
Not able to diagnose such a problem without looking at the truck. Have the dealership troubleshoot. Still got warranty?
Mar 02, 2009 | 2004 GMC Sierra 2500
SHORT ON POWER SUPPLY
If it only goes into protect mode after the remote voltage is applied, the amp probably has shorted output transistors.
Nov 06, 2008 | Soundstream CAR AMPLIFIER, 1 CH, 1000 WTS...
Sounstream tra 560.2 always in 'protect'
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 01, 2008 | Soundstream Tarantula Car Audio Amplifier
Cutting out intermittent problem
If the voltage is dropping to 8v, it sounds like there is a problem with either the B+ line or the ground connection. You should also check the voltage across the battery terminals to see if the voltage is dropping at the source.
The amp may be going into protect mode. Disconnect all speaker wires from the amplifier's terminals. Also disconnect the RCA cables from the amp. Does it still go into protect?
Insert a 20 amp fuse in the B+ line and try to power it up. If the fuse blows with no speakers connected to it, the amp probably has a blown channel.
Dec 05, 2007 | JBL GTO75.4 Car Audio Amplifier
Amp staying in protection mode
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Soundstream RUB1.2500D 2500 Watts RMS Mono Block Rubicon Series Subwoofer Amplifier Logo
223 people viewed this question
Top Soundstream Car Audio & Video Experts
richie46
ray gallant
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
