Question about Electralog Home
Heat stops working after a few minutes
Model D. Heat stops working after a few minutes.
    Problem Solver:
  • 14 Answers
A manufacture name and what type of heater would be helpful.
Posted on Jul 29, 2014
Duo Therm Heat Pump Does not Run, Shows Aux Heat Mode, Switches to Furnace Heat
The control that monitors the cutoff temperature may need to be adjusted. Your hetpump may also work effectively at 16 degrees. you have not left any information on the make or model of the heatpump or the thermostat.
Aug 16, 2014 | Heating & Cooling
I have a Kenmore 90 Series gas dryer model num 11074902200 that won't heat up. the drum spins and the heat will turn on for a few minutes then it stops heating up. I replaced the glow igniter but the...
The flame sensor is fine because it is powering up the ignitor. The dryer does heat a little. It can be only one thing: The solenoids are aged and weak. They work at first then the heat up and quit.
How to video
Service manual and more HERE
Sep 08, 2011 | Dryers
Am using an mPAQ model:M66SE laptop. it heats up very much and after few minutes it hugs up.until i restart and wait few some minutes and cools. what will i do. the heat sink on top of the south bridge is...
remove your heat sink then clean the surface of the heat sink with clen cloth apply athin layer of heatsink compund and fix the heat sink tightly if the heatsink is dried or worn out the heatsink gets heated up also check the fan is working
Mar 28, 2011 | Compaq Heatsink CPU Heatsink & Fan
My frigidaire gallery model fsg748gfs gas dryer starts to heat up but stops after a few minutes?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire FGQ332ES Gas Dryer
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
Heat only works for a minute and then the heat stops
There is a thermostat that regulates temperature. Your dryer MIGHT be overheating. Check your lint filter, vent, and vent hose for blockage first. If not, it might be time to replace the heating element.
May 18, 2009 | Whirlpool Dryers
Heater runs hot for a few minutes then stops heating
I would say from what you have described your problem is a bad thermostat heat sensor (you may have to replace the whole thermostat on this model!) This is a very common problem for this unit!
Please rate my sesponse!
THANK YOU
Jan 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Home Logo
278 people viewed this question
Top Electralog Home Experts
Donni Steen
Tom Chichester
Are you an Electralog Home Expert? Answer questions, earn points and help others
