Question about Samsung Galaxy Tab on 3 Mobile Tablet PC
Battery not charging
Had a complete flat battery and been charging for 4 hours or with battery still not charged
  • 48 Answers
Are you using the charger that came with the tablet? If you are using a cell phone charger...it will not work. The tablet charger is rated for 2.1 A. Most cell phone chargers are rated for less than 1 A.
Posted on Apr 25, 2014
Was only showing battery charging but not moving. now it wont charge or come on. please help. thank you. stephanie
Stephanie, could be a faulty charger or battery, try and borrow a friends charger if you can and try and see if it charges then you know your charger is bad, if it does not charge the your battery needs replaced.
PRESS THE HELPFUL BUTTON
Feb 06, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
Tablet will not charge
Assuming that you charger is not defective, and that you have no other electrical issues, then if your battery has been allowed to completely flat line, it may no longer accept a charge from the normal wall charger. Then you can try to trickle charge your tablet from a low voltage/current source, such as a USB port or a low power phone charger (5v/500ma). Try a trickle charge for 8 - 24 hours on your tablet. After that try your normal charger and see if it will now charge properly.
If that does not work, and you have previously ruled out your charger, then I would suggest contacting the manufacturer, as it is likely some other fault, either with the battery, or the tablet itself.
I post on behalf of HP.
Jul 31, 2015 | Tablets & eReaders
Info on charging a DL1010
charge for 8 hours minimum,,,a down battery,,,,,
no need to accuracy for charging time ,,,when charge complete= stoppscharging automatically
Mar 14, 2015 | Tablets & eReaders
Nextbook8 on charger 8 hours. An only 60% charged this time?
Good evening
This happened to my iPad. When I discovered that there were many programs open, I closed them and it charged.
hope this works for you as it did for me. Some one told me that it was a good idea to plug the tablet to a computer and charge it that way.
kolbrun
Feb 08, 2015 | Nextbook Premium 8 Se Android
My iPad 2 won't hold a charge
Bad battery pack. Suffer with it, or buy a replacement.
Jul 30, 2014 | Apple iPad2 WiFi 64GB
Why will a samsung galaxy 2 tablet not charge?
first go to a mobile shop ask hif it it is the problem of battry or some hardware problem inside the tab and also check the charger weather it works or not
Jul 24, 2014 | Samsung Galaxy Tab 2
Forcd Factory Reset
best learn the principles of your tablet first
first when a battery is less than 10% it takes up to 5 hours to recharge not 5 minutes
next many tablets do not recharge when in operation so you have to shut down to allow the recharge to work
because the battery was dead flat , of course it will reset as that is the same as removing or installing a new battery
Nov 11, 2017 | Polaroid 7-in. Internet Tablet - Other
New Samsung Galaxy Note 10.0 battery life and charging time
Sounds normal to me!!
The further away from wifi router you are the more power is needed by the wifi card.... etc etc so the 8 hours is in perfect conditions with the screen brightness at minimum and no apps running!! It's safe to say that, whatever battery life is quoted for any device you should only expect to acheive half that in the real world.
The screen is prob responsible for 80% of the battery's power drain. Turn the brightness down. Stay in same room as router. close down un-used apps that demand cpu and network (wifi card) time.
Shut it down completely when charging don't just let slip into standby. Also don't charge it on a cold or hot place such as a window sil. To high or low tempretures will increase charge time and will damage the battery lowering it's capacity.
May 30, 2013 | Samsung Galaxy Note 10.1
Battery fails to charge completely
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Nov 02, 2008 | Gateway CX200S Tablet PC
Samsung Galaxy Tab on 3 Mobile Tablet PC Logo
157 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
