One original bulb burnes out & the other one stayed on. Bought two replacement at Rona, both lights stay on
SOURCE: Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
SOURCE: Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
SOURCE: GE microwave JVM1631BJ01 while replacing
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
This can often also
affect the exhaust fan operation, too. The lights and fan can be
inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your
full model number) for more information & help.
We're
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: interior light staying on in GE JVM1790 and
This
is usually caused by either a bad door switch or a loose door switch
mount, which are pretty simple problems to fix.
Since
it's less than one year old, it would be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find a
GE-authorized servicer by calling GE Appliance
Service at 1-800-848-7620 or here.
We're
SOURCE: replaced cook top night light bulbs and now they will not dim or
week or so.
At
The lights can can be
inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly
affect the fan operation or inside light, too.
full model number from the tag on the unit) for more
information & help.
We're
William E. Miller, AS-EET
[email protected]
Microwave Oven Control Panel Repair Nationwide
