Clicksure login having problems getting started
On start all I get is the starter relay click is the starter my problem, this is on a 2006 yamaha silverado 1100
flat battery?not charging ,fuse ? have you tried bump starting? if you have igniton lights it should have enough charge to start the engine,if you get running, get it in neutral & let tick over for a short while then switch off, then try start, if clicking still occures then replace battery.
Sep 06, 2014 | 2006 Yamaha V Star 1100 Classic
Starting problem
if the bike is not turning over check battery and starter if bike is turning over check compression make sure its getting spark and make sure its getting gas somettimes to the key switch will go bad or ur kill switch is turned of or not working
Feb 11, 2014 | Bajaj Pulsar 180 Motorcycles
I have a problem with my z71 v8 pick-up in the morning when i first start it i have a hard time starting but once it starts it fine after the first start it has no problem starting when u shut it off i...
run the fault codes
indicates a problem ambient temp or baro sensor not reporting to the ECM to get the correct air/fuel ration for starting ( as in the old choke application)
Aug 12, 2017 | 1998 GMC Sierra
Hello i have nokia 6600.my problem is that it
this may be a battery problem dude , i hope change the battery may fix the problem otherwise there will be a problem in mobile hardware
Jun 19, 2010 | Nokia 6600
I have a Cub Cadet Tank. Having problems getting
starting fluid spay in carb or carb clean check the fuel needle valve in carb make sure it is turned all the way in and 1-1/2 turs back out
Jun 07, 2009 | Garden
Starting problems
it sound like you have a imobalizer fault and yor not getting fuel get a friend to listen under the back of the car as you try to start it . you should get 3 seconds of prime before ignition then once started it will pump normaly.
May 06, 2009 | 1991 Subaru Legacy
I can get my 1995 jeep wrangler 2.5 4 cyl engine to start, but right after it starts, it dies on me. Replaced the coil and the map sensor, but still have the same problem. Right after it starts and dies, I...
Get a can of starter fluid and spry some inside the carburetor, if the engine start you have fuel problem, check inline filter, check pressure fuel. If problem is resolve pour a can of B12 liquid inside the gas tank. This liquid will clean, water, fuel ejectors and fuel line.
Mar 16, 2009 | 1995 Jeep Wrangler
Starting grand am
Sounds like a bad connection problem at the items you're moving around to finally get the car started. Read what you actually wrote. You'll see that you answered your own question. Start by confirming the connections at the items you're moving around.
Dec 27, 2008 | 2003 Pontiac Grand Am
Starting Problem
The starting problem sounds like a weak fuel pump not having enough pressure to open the injectors on start up, this a common problem with these trucks. The pressure required to keep it running is lower than the pressure required to start it. You should be able to start it back up when it is warmed up but not on a cold start. These are the symptoms of a weak pump and they will only get worse. Your heating problem may be an air pocket in the heater core this is a known problem on the S-series. Try to elevate the front of the vehicle as high as you can then turn on the heat and try reving the motor if the air pocket is your problem this should take care of it. Let me know if i can help further and please rate.
Dec 27, 2008 | 1997 Oldsmobile Bravada
Starting problem
start pc...after bios screen loads press F8 in order to get to safe mode options......in the list there is an option to repair windows startup problems...choose that option....it takes a little while to repair so be patient but your machine should start normally
Dec 10, 2008 | Compaq Presario Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
