Question about Kenmore Humidifiers
Need owners manual
It quits running and also flashes numbers on the screen. not sure what the two green buttons mean mine is a model # 15420
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kenmore Master
  • 102,366 Answers
You may download a copy of the manual at http://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L0606248.pdf
Posted on Mar 30, 2014
My Kenmore Humidifier 15420 has a code of "cf" what does it mean?
Depending on your model, the CF could mean the filter needs to be changed or that the unit needs to be reset. If your model doesn't have a reset button, you can unplug the unit from the outlet for 5 minutes.
Jan 18, 2017 | Kenmore Humidifiers
CL error code
The CL code means that the "Control Lockout" function has been activated. This prevents the buttons from functioning. To deactivate it (re-enabling the buttons), hold down the power button for five seconds. See the manual for more info:
http://www.searspartsdirect.com/partsdirect/user-manuals/9962/758154080-Kenmore-Parts-HUMIDIFIER-manual?pathRender=fromManualTabPage
Jan 13, 2014 | Kenmore Humidifiers
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
http://www.hunter-humidifiers.com/manuals/34357.pdf
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
I have one of these and I have no clue how it works, sometimes the water reserve catches water.. does that mean its dehumidifying? What are some of the settings I should put it on?
Yes, that means it's working, Basically, the lower the humidity setting, the more moisture it removes from the household air. The higher the setting, the less it will remove and run less, too. Once the water reservoir or "bucket" as most folks call it, is full the unit will shut off automatically and the bucket FULL light will come on. You will need to remove the bucket from the front of the unit and empty it (I prefer emptying it in the bath tub or shower). Then carefully replace it the unit, so that it triggers the safety switch and the FULL light goes out and the unit will restart automatically, if necessary.
You didn't list the model number of your Danby Dehumidifier. But all Danby units work pretty much the same. To help you further I have included a link to the Owners Manual for the Danby DDR25E (this also covers 2 other models) that you can download and print for future reference. Read it thoroughly and become familiar with it's operation and the required Routine Maintenance.
http://www.danby.ca/cms/uploads/products/en_manual
/DDR25E%2C_DDR30E%2C_DDR45E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 25, 2011 | Danby (DDR600R) Humidifier
How do you set and or reset the "filter replacement"schedule on the April air #700 model?
The owner's manual reads "After the Water Panel is replaced, turn the Control knob to the “Test/Reset” position until the green “Humidifier ON” light flashes, to reset the Water Panel change timer."
Hope you find this to be very helpful.
Let me know if you have any questions. :-)
Mar 20, 2010 | Aprilaire 700 Humidifier
Honeywell TrueStream Humidifier issue
there is a bank of dip switches to the left of the low voltage connections almos middle of humidifer on the green control board the numbers are clearly above the switches
Apr 06, 2009 | Humidifiers
What does the yellow light mean?
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
Dec 13, 2008 | Crane Cow Humidifier
Humidifiers Logo
148 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
