Question about Dell Inspiron All-In-One Computer
White images too bright
White objects have no contrast. Washed out. Gamma/Brightness/contrast (hardware and software) function as designed, but do not resolve issue.
    Top Expert:
  • Dell Master
  • 12,962 Answers
Try plugging in another working monitor into the monitor output - if results are the same then the problem lies with your video circuits in your all in one. Hopefully it is under warranty - if not you are screwed because those all in one units have nothing but proprietary parts and are very costly to replace/service. If the external monitor works fine then the problem lies with the display or screen of your all in one.
Posted on Mar 31, 2014
  • 7 Answers
SOURCE: Cannot set the brightness, contrast. Locked menu. Dell LCD.
Niceeeee! this really fixed the issue after 15 seconds with the menu button preessed down the lock became unlocked. MAGIC!
Posted on Mar 25, 2010
  • 4 Answers
SOURCE: E510 -- going blind.
The brightness and contrast can be adjusted on the monitor itself with the help of buttons on it.
Posted on Sep 26, 2010
damnor01
  • 1179 Answers
SOURCE: my dell inspiron 546's monitor has gone dark the
It might be that the CFL lighting tubes on your monitor have failed, in which case they need to be replaced. Borrow a screen to try on your computer to test if it is in actual fact the your screen that is faulty. This is normally fixed by a computer technician! If it is under warranty return it!
damnor01
Posted on Nov 27, 2010
  • 12 Answers
SOURCE: cant get the black box off my pc screen that says brightness/contrast
Try clicking menu button on your monitor a few times.
Posted on Dec 31, 2011
  • 21 Answers
SOURCE: my brightness/contrast menu keeps popping up on its own
Check if the brightness button stuck or jammed.Try to release it.
Posted on Jun 08, 2012
My monitor stays white it wont show any display
black-icon.gif This icon indicates the BRIGHTNESS control, more properly called BLACK LEVEL. It adds or subtracts an offset, or bias, into the red, green, and blue signals. This control should be adjusted so that black picture content displays as true black on your monitor. Misadjustment of this control is the most common problem of poor quality picture reproduction on computer monitors, video monitors, and television sets. Later in this document, I will explain how to set this control properly. The setting is somewhat dependent upon ambient light. Modern display equipment is sufficiently stable that frequent adjustment is unnecessary.
picture-icon.gif This icon indicates the CONTRAST control, preferably called PICTURE. It applies a scale factor (gain) to the red, green, and blue signals. It affects the luminance (proportional to intensity) that is reproduced for a full white input signal. Once BRIGHTNESS is set correctly, CONTRAST should be set for comfortable viewing brightness.
The gamma can be controlled through Video Card utility which can usually be accessed by going to display properties.
Depending on your video card software you may be able to right click your desktop, select properties, select settings tab and then choose advanced, towards the bottom. In there you may find a tab called Monitor and under that tab you may or may not (depending on your video card software) be able to adjust your color correction settings(gamma & brightness & contrast).
. Right click on the desktop and then select Properties
2. Click on the Settings tab and then click on the Advanced button.
3. Click on the Color Correction tab and you will see settings for Brightness, Contrast, and Gamma
Jan 29, 2010 | Computers & Internet
Cannot change the brightness
to adjust brightness levels you might want to modify ONLY the brightness, contrast and gamma settings. Others might mess up your colors or god knows what. You can also set up the GPU's brightness settings by going to the gpu's control panel, usually opened by right clicking the desktop and selecting your video card's control panel option. Then adjust the brightness, contrast and gamma options to suit your needs. Hope that helps!
Jun 10, 2009 | Hannspree HW191D LCD Monitor
Fix an overexposed pic with photoshop 2000
Look for a "gamma "function" I am not 100% sure about photoshop but most graphics manipulation software has thsi and usually there is a a brightness / contrast function that is also quite often associated with the GAMMA
Apr 19, 2009 | Computers & Internet
IBM t43 gamma issues
for windows Xp its easy ..just right clic on desktop .../propieties..and choose the last one ...settings ...or right clic on the image driver icon on ttray system ( bottom right of task bar ) and choose rgb setings ...or so ..
for vist you have to go on right clic on monitor / personalize...and choose collor management ...there yo will have options ...
Mar 03, 2009 | IBM ThinkPad T43 Notebook
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Brightness adjustment not very effective - XP-sp2
Alter your gamma,brightness,contrast,etc with your grapics card settings,
Mar 01, 2008 | Acer AL2016W 20" LCD Monitor
My monitor's white balance is all out of whack!
your problem is the connection to your cpu connect it propely and make sure it is STRAIT if the problem persists contact me
Aug 17, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Image adjustment functions
SHARPNESS - The function is to adjust sharpness of capturing images. CONTRAST - The function is to adjust contrast (distinction between light and dark) of capturing images. SATURATION - The function is to set color depth of capturing images. GRADATION - In this function, you can select the brightness of an entire image. It is suitable when you want to add a brighter effect to a bright object (Hi Key) and a darker effect to a dark object (Low Key).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Dell Inspiron All-In-One Computer Logo
41 people viewed this question
Alun Cox
