Question about NEC Multeos M46 46 in. LCD TV
Is there a way to reset the M46 to factory defaults without using the onscreen menu?
The M46 will display basic "display" screen, volume, mute, but does not display the OSM screen, or any inputs. It also seems as though a lot of the "remote" keys do not work.
    Top Expert:
  • NEC Master
  • 74,666 Answers
No. There is no other way to get it to its factory reset; without entering its service mode. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Posted on Mar 31, 2014
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
How do manually reset sansui lifepad to factory default settings
Try this:
1. Hold down power and volume up buttons for 10 seconds, then press volume down button.
Failing that, this:
1. Turn tablet off. Hold down power button until 'Device Option' menu appears.
2. Select 'Power Off' then 'OK'
3. When tablet has switched off, hold the 'Reset' & 'Power' buttons simultaneously for about 10 seconds.
4. Wait for screen display, then press 'reset' button.
5. The 'system recovery' screen should appear.
6. Use 'Home' & 'Menu' buttons to navigate the menu.
7. Select the 'wipe data/factory reset' option & press 'Reset' button.
8. Then select 'Yes- delete all user data' & press 'Reset' button.
9. Press the 'Reset' button to reboot/restart tablet.
Oct 15, 2014 | Computers & Internet
How to hard reset lg g2
1.Turn off the phone first.
2.Press the "volume down" button, while holding the power button down at the same time.
3.Hold them down until the android figure comes onscreen and/or the phone vibrates.
4.There should be a menu onscreen about now. From here you should use the volume up/down buttons to scroll through the menu of what you want to do. Select "Clear Storage" from the menu. This will set it back to the factory default. Oh, as you shouldn't be using the screen for this part, use the power button to confirm your selection. Hope this wasn't as clear as mud!
Jul 23, 2014 | LG Cell Phones
How can i unlock a tablet without the pattern code and no internet available ?
  1. Below is the process to tell you how you can hard reset your tablet:
  2. Ensure that the tablet is powered off.
  3. Press the Power and the Volume Up button together till the device displays the start-up logo.
  4. Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  5. On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  6. Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
  7. On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  8. Press the Power button to hard reset the tablet device while clearing the cache along with the process.
  9. Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your tablet.
Jun 21, 2014 | Google Android
Vizio tv problems
Have you checked the TV without other devices connected to the TV.
Eg. disconnect any home theatre or speakers from the TV.
Verify with audio menu if the settngs of TV speakers is on or off ?
To adjust the audio settings:
1. Press the menu button on the remote. The on-screen menu
is displayed.
2. Use the arrow buttons on the remote to highlight audio and press ok. The AUDIO menu is displayed.
3. Use the arrow buttons to highlight the setting you wish to adjust, then press left/right arrow buttons to change the setting:
• TV speakers - Turns the built-in speakers on or off.
Lastly have you tried restoring the TV to factory default settings.
To restore the TV to its factory default settings:
1. Press the menu button on the remote. The on-screen menu is
displayed.
2. Use the arrow buttons on the remote to highlight system
and press ok. The SYSTEM menu is displayed.
3. Highlight reset & admin and press ok. The RESET & ADMIN
menu is displayed.
4. Highlight reset TV to factory defaults and press ok.
5. If you have changed the default parental control passcode,
enter it now.
The TV displays, "Select Reset to restore all TV settings to
factory defaults and clear all account information."
6. Highlight reset and press ok.
7. Wait for the TV to turn off. The TV will turn back on shortly
afterward and the Setup App will begin
Apr 29, 2014 | Televison & Video
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
Cannot have 2 phones in use at the same time 25952
Here is a selection from the manual and a link to the full manual to download.....it should help.
http://www.home-electronics.net/ge/pc/IB/25952EE2_IB.pdf
Transfer ON/OFF
In order to use the Call Transfer feature (applicable ONLY with additional handsets), you must have the Transfer ON/OFF set to ON through the menu of the transferring handset.
1. Press the mute/menu button until TRANSFER 41OFFshows in the display.
2. Use the CALLER ID-VOLUME (5or6) button or the touch tone pad on the handset and select 2ON.
3. Press mute/menu again to save.
Default Setting
You may return handset settings to the factory default setup using this menu.
1. Press the mute/menu button until DEFAULT 4NO shows in the display. NO is the default.
2. Use the CALLER ID-VOLUME (5or6) button on the handset to scroll to YES or NO.
NOTE: If you choose YES, all settings in the programmable menu return to the factory defaults.
Jan 27, 2008 | Uniden Cordless Phone
NEC Multeos M46 46 in. LCD TV Logo
100 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
