Question about Fender Music
Acoustasonic sfx I've had mine for several years, never had any issues with it. Turned it on and it won't do anything, power is plugged in, but no lights or sound. The only thing is what sounds like a faint humming sound coming from the top of the cabinet. It's way beyond warranty, but I'd like to get it fixed if not to expensive to fix. Cheers, David david@savedge-music.com
    Scholar:
    New Friend:
  • 78 Answers
Have you checked the fuse in back?
Posted on Apr 20, 2014
  • 4234 Answers
SOURCE: something has blown?
The output transistors may have shorted and caused a resistor to smoke (literally!!). This should not be too expensive a repair for anyone that works on these amps. Figure on $20-$30 for parts.
Dan
Posted on Feb 23, 2009
SOURCE: The 'protect light' comes on Fender PD150 Portable Sound System
The protect circuit is activated by a current sensing transformer in the *input* of the power supply. If any of the subassemblies of the unit (or all of them in combination) draw excess current then the protect light will illuminate and the power supply shut down to prevent any damage to the system.
The circuitry in the power supply is fairly robust as well as fuse protected so it is unlikely that the power supply itself has failed. More than likely one of your output power transistors has been shorted and it is easy to check this yourself if you are interested in doing so.
Furthermore if you follow a few *simple* precautions you can do this safely and confidently.
Post again on this thread if you are interested and I will spew the details.
-BK
Posted on Mar 14, 2009
soundchasr
  • 11 Answers
SOURCE: NO sound through the AMP even though the power light comes on
Not a fuse. First thing, to check your speaker (amp unplugged, of course), touch the + and - speaker connections to a 9V battery. If you don't hear a pop sound then your speaker is blown. Thus, no output sound. If speaker is OK, then the output IC is your problem.
Posted on Jul 25, 2009
  • 5603 Answers
SOURCE: Lexicon alpha interface is recording a faint high pitched sound
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Posted on Aug 24, 2009
  • 5603 Answers
SOURCE: My casio ct670 ToneBank keyboard isn't making much sound
Check that you don't have old batteries in the unit. Also that the auto power down is not activated.
If using a power adapter make sure it is the RIGHT one, both in polarity and current rating.
Posted on Sep 22, 2009
Testimonial: "Sorta helpful. How do I check for auto power down activation? Thanks for responding so soon. I'm not using batteries and used the original ac adapter."
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
My peavy amp will not turn on
1- check the outlet for power by plugging in a lamp or something
2- check the amps fuse. Most power amps have user replaceable glass fuses.
Aug 17, 2012 | Peavey Bandit 112 Guitar Amplifier With...
I just traded for a Fender Acoustasonic Jr. DSP. Everything is great except some humming noise when I plug a 1/4 inch instrument plug into the second/vocal channel. I don't know if it would do the same...
This probably an impedance problem. Do you have the manual. If not see if you can get it on line. You can then research the impedance of the input and see if you have a problem. Fender website in support area. Hope that helps. Let me know..
Jul 25, 2011 | Fender Acoustasonic Junior Dsp Combo...
Fender Acoustisonic Jr. One day I played it at its highest volume, then turned it off. Came back to play it 20 min. later and it wouldn't make a sound. You can slightly hear the guitar buzzing when...
I would try using another speaker to see if you can get the sound back, this will help you narrow down the problem, you can also use the effect send to feed anothe amp to see if you get the sound OK.
It can be blown speaker or output stages,
Jul 08, 2011 | Fender Acoustasonic Junior Dsp Combo...
Fender acoustasonic junior crackling loudly and electronic buzz when touch volume knobs
noise problem with fender jr accoustatics is the poor aluminum sheet ground design that wraps around the body of the amp. it happens to me all the time because i kept on moving/carrying/dropping the amp every time we do church service. i am thinking of using an aluminum cable to wrap around outside the body.
Jul 07, 2011 | Fender Acoustasonic Junior Dsp Combo...
I recently had my fender acoustasonic telecaster checked out because the volume kept shorting out. It seems the volume pot was dirty or had a short. Took it to my local fender guitar and fender electronic...
If the problem is actually the volume knob, then the guitar shop did not fix it and you should bring it back. There is a test you can do to see if the problem is your volume knob. With the guitar unplugged, you can turn the knob up to the max and down to the min a lot of time (like 50-100 times or more) plug it back in and see if the problem is a little bit better, if it is I would bring it back to the repair shop and demand they fix it properly.
The problem could be the cable you are using. Sometimes it can seem like it's a volume knob problem when really it's a cable issue. Jiggle the cable and connector while the guitar is plugged in to see if the sound cuts out at all or you get crackling.
May 04, 2011 | Fender Acoustasonic Telecaster 3TSB
I have a Fender Acoustasonic DSP 30 (Two 8" speakers) and recently my effects on both the instrument and vocal channels have topped working at all. I heard a small woooosh and a light pop sound, so...
Wrong assumption ! Most likely an electrolytic capacitor blew up. If you open the unit it should be obvious... it MAY also have taken out another component(s) as well. They can make a mess so clean up any residue as it will cause corrosion. Use distilled (non-ionic) water to clean up the residue. The little cans sometimes blow off or spit at the top and spew white crud all over.
Apr 13, 2011 | Fender Musical Instruments Corporation...
It works sometimes but mostly never. The power is on and the screen is blank.
For anyone who still has this issue including above morris_gray,
I've encountered this myself with my first generation M-Audio Axiom 25 USB MIDI Controller plugged into a MacBook using GarageBand (G2 apparently has identical malfunction).
It should be noted that I never installed any type of software for the device, that came with the device. I simply wanted a controller for GarageBand, and I will also note that it has worked flawlessly for about 4 years on this setup, until about a week ago...
I'll provide what information I have gathered about the blank LCD screen issue as well as the controller simply not functioning correctly as listed below:
The most common way people test/fix this is to "hard reset":
- turn controller off (assuming you've kept the usb cable connected to your computer)
- hold down both the + and - buttons directly below the lcd, and simply turn the power on. Some numbers should appear on the lcd soon after the reboot and you are okay to release said buttons...
I've read testimonials, watched videos of people doing this and successfully getting their device back in action, though the reset will default anything you have saved for the device.
Sadly, this did not work on mine. I've tried several different cables- in several different usb ports- on several different computers (as suggested by M-Audio on their support page. I still get a lit up but blank lcd. I've even tried to still use it but only some awful noises come out and nearly every function just makes the thing freak out and it becomes silent/unusable/useless.
M-Audio suggests sending it back to them for fixing at this point.
Because I've had my Axiom 25 Gen. 1 for so long and I have never installed anything what so ever that came in the box, and have little faith that M-Audio will replace mine, I will most likely try to take it apart and mess around with the electronics inside as it's just a big paperweight now.
I did read that in the Gen. 1's the blank lcd could be a result of a chip gone wrong, so to speak... Gen. 2's had some type of "grounding" issue that resulted in the blank lcd and such.
I hope this helps anyone, if I stumble upon a way to fix this through my own curiosity I will inform the masses...
I'll be on the hunt for a new controller most likely and it probably wont be an M-Audio...not that I'm upset with the product, it lasted me quite a while and I've made a lot of solid songs/music with it, but rather I feel the need for something different and maybe a little more sturdy that can actually be a synthesizer on its own, not just a controller.
- Christoffer
Mar 29, 2011 | M-Audio Axiom 25 G2 USB MIDI Controller
Music Logo
49 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Are you a Fender Music Expert? Answer questions, earn points and help others
